Question about Hitachi 50SBX70B 50" Rear Projection Television
My 50SBX70B doesn't start
Everytime I turn on the TV (50SBX70B) ON button within a second TV turn.
Posted by Mr Patel on
Anonymous
What is E994, Q777.and C701(.001/2kv
Posted on Mar 31, 2008
Anonymous
I was actually wondering where to fine E994
Posted on Jan 11, 2008
Anonymous
    Scholar:
  • 87 Answers
There are many reasons for a no start on your 50SBX70. I will give you the most common problem I have found. Check E994( 4a pico fuse on the 120v line in pwr supply) If it is bad, remove C701(.001/2kv) from the circuit located near Q777. Inspect the capacitor for any burn marks, if so put in a new fuse and leave the cap out and fire up the set.
Posted on Nov 07, 2007
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
Kia rio air conditioning light?
The manual instructions are basically:
Turn the fan to 0 (off, far left).
Turn the air control to full defrost (far right).
Press the recirculation button at least 5 times within 3 seconds.
If you've done it right, the recirculation button light will flash a few times at about 1/2 second intervals.
I've tried it on mine and this works.
Feb 14, 2009 | 2003 Kia Rio
How do I turn off the change oil light on a 1994 corvette
1. Turn the key to “Run,” but don’t start
2. Press “ENG MET” on the Trip
the engine.
Monitor. Then, within five seconds,
press it again.
3. Within five seconds, press and hold
“GAUGES” on the Trip Monitor. The
“CHANGE OIL” light should flash.
4. Hold the “GAUGES” button until the
“CHANGE OIL” light stops flashing
and goes out. This should take about
ten seconds.
When the light goes out, the monitoirs
reset. If the monitor doesn’tr eset, turn the
ignition off, then try again.
Nov 18, 2008 | 1994 Chevrolet Corvette
Please help need to watch tv
Well this gives you someplace to start!
Symptom: NO POWER
Cause: DEFECTIVE I912
Symptom: SHUTDOWN
Cause: Q777,I901
Symptom: SHUTDOWN
Cause: E994,D724
Symptom: SHUTDOWN
Cause: DEFECTIVE I401
Symptom: SHUTDOWN
Cause: DEFECTIVE I601
Symptom: SHUTDOWN
Cause: DEFECTIVE C715
Symptom: SHUTDOWN/OPEN E995,E996
Cause: DEFECTIVE T702
Jan 29, 2008 | Hitachi 50SBX70B 50" Rear Projection...
My 50SBX70B flicks than lost the power
Symptom: NO HOR SYNC
Cause: DEFECTIVE I008
Symptom: No Horizontal Sync. When PinP is called up, main picture may lock up for a 8 moment, then it goes back out of sync.
Cause: I008 defective (Sync Switch)
Jan 15, 2008 | Hitachi 50SBX70B 50" Rear Projection...
I have a hitachi 50sbx70b
sounds like either a tube is arcing or h.o.t is arcing.
Nov 12, 2007 | Hitachi 50SBX70B 50" Rear Projection...
Televison & Video Logo
182 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
