Because of the epson status monitor my printer refuses to print when I'm using refilled cartridges. Apparently I should be able to turn it of, but I can't find where or how. Thanks
SOURCE: epson stylus cx9400fax series printer
There is no chip resetter for this model at this time. However, one is to be available in the near future. So for now you must purchase new/refilled cartridges.
SOURCE: Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
SOURCE: Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
For the Epson R200 here's how I got it to work with Vista Business 32bit ...
#1 Disable AV software
#2 Open the CD for the printer software
#3 Find the launcher, right-click it and select Properties, then select the Compatibility tab
#4 Choose XP SP2 compatibility mode and Run As Administrator, then click OK.
#5 Double-click the launcher to start the program, select Custom then
then choose only the Driver and Status Monitor applications.
Worked for me, hopefully will do too for you. :o)
Install your cloned ink cartridge into the Epson printer.
Go to "Start > Control Panel" on your computer.
Double-click on "Printer."
Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
Click "Save" and close the windows. Your cloned ink cartridges should now work.
Compatible laser & Inkjet cartridge CISS,Bulk Ink,Refills & Photo paper
professional only about toner chip toner cartridge chip
Count, Charge, Report Printing. Download Free 30-day Trial Now.
True solvent Ink Piezo Inkjet print Distributor Wanted, Made in Korea
