Epson Printer Logo
A
Anonymous Posted on Jul 05, 2014
How to reset epson pm 245 ink pad - Epson Printer
3helpful
Mp 245 Epson Printer ink pads are at the end of service life how to reset
Download Adjustment Program Epson R200, R210 Download Adjustment Program Epson R220 - R230 Download Adjustment Program Epson R240 - R245 - ...
tip
Manual Counter Reset Method
To manually reset the Ink Jet Counter that compels you to clean your waste pads. For the tip on how to clean your ink waste pads go here.
Please Note: In some cases, your printer may be leaking ink so much and so often that not only does your ink pads need cleaning, but you may need to replace the ink reservoir on your printer or you will have a leaking mess on your hands. This is a decision and judgment only you can make. If your printer is leaking quite of lot of ink, you may have to take it to an authorized Epson Repair Shop or Person. Find an authorized location by starting at Epson.com
The solution below is valid for most of the following printer models listed below this solution, some listed may not work, some not listed may also work it varies as this method is listed below is illegal for an authorized Epson Tech to release.
Thanks to the many user boards on the Internet for this solution that I know has worked for people I've helped here on FixYa.
Don't be discouraged if it doesn't work the first time. The key is in pressing the buttons exactly at the same time. So if this doesn't work the first time, try again and try again. Most people state they get it eventually.
[thanks to fixyourownprinter.com for the crux of this particular solution]
"Printer Onboard Control Panel Key Sequence"
"Press and hold the paper feed, paper switch and the power switch.
Once the power light and paper light flashes twice and the other lights are flashing release the paper feed and paper switch "and then press the paper feed switch".
The power, paper and ink lights will flash twice. At this point the protection counter has been reset."
Don't give up, if it does not reset the first time. The timing is tricky for some people.
Supported Epson Models that I am aware of, others not listed may work and some listed also may not work, it varies but don't be discouraged to try and try again.
You can also try the software download solution listed in this tip I posted.
Epson Stylus Сolor 400
Epson Stylus Сolor 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Сolor 600
Epson Stylus Сolor 640
Epson Stylus Сolor 660
Epson Stylus Сolor 670
Epson Stylus Color 680 / 777
Epson Stylus Сolor 740
Epson Stylus Сolor 760
Epson Stylus Сolor 800 / 850
Epson Stylus Сolor 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Сolor 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
1helpful
How to reset epson t 60 printer
Depends on what you mean by "reset".
If you're referring to the waste ink counters, you can either:
  1. Locate a copy of the AdjProg service utility and use that to reset the waste counters
    Note: Will not work on MacOS or Windows 8
    ... or...
  2. Download the WICReset (for windows) or iWIC (for MacOS) and purchase a WICReset key to reset the waste ink counter that way.
Whatever you do, remember that resetting doesn't deal with the waste ink inside the pads so you should be looking at changing the pads (not easy to do yourself) or fitting an external waste ink tank like a printer potty.
Epson pm 245 ink pads
The printer's ink pads are at the end of their service life.please contact Epson support.
1helpful
340helpful
14answers
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
How reset E-91 ( wast ink ) ( reset tool ) on epson stylus rx 520
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
2helpful
Epson c70 problem
Re: Epson C70 Problem by Denny Conway (12/18/03 9:05 AM) reply + / - Aspah:A Service Error where all LED's/Lights are blinking at the same time,is normally a Maintenance Request Error, which is actually a Waste InkPad Overflow Error...JUST SO YOU WILL KNOW: On most Epson's, while theprinter is in this error condition, it disables all operations,including data communication. Normally your remedy is to replace theWaste Ink Pad/Pads with a new one/ones and then reset the InternalWaste Ink Pad Counter. If you just reset the counter and don't replacethe pads, then your printers old pads will eventually overflow andnormally start leaking ink out the bottom of your printer. You may wantto try doing a general search on the "fixyourownprinter.com" printerrepair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.You should be able to find quite a few references listed in the lastsix months and most included web-site links, for possible help on thereset procedure. Some also list links where you can purchase a SERVICEMANUAL, in case you want to try and do the service yourself...GoodLuck! Denny Conway...P.S. THIS INFO POSTED BY "WES" MIGHT HELP: Wes12/07/2003 13:57:30 To see what's involved in servicing the waste inkpads try this http://www.epsonhelp.web1000.com/wip.html ...IF you just want to reset the wate ink counter you can use this program http://inkjetprinterhelp.us/epsonSSC.html.Resetting the ink counter will stop the lights from flashing butcleaning/replacing the ink pads is recommended. ...OR... Tim H12/10/2003 2:46:24 Subject: Epson Reset Program Download Location.after a long search for a reset program for waste ink, without paying,i found it. goto: http://inkjetprinterhelp.us/sscserve.exe ...please check that your printer is compatible goto: http://inkjetprinterhelp.us/epsonSSC.html ...p.s: this program has other features as well.
0.gif Re: Epson C70 Problem by Jim (12/21/03 4:10 PM) reply + / - I have just installed colour cartridges and a black cartridge into my C70.
Myproblem is that the black cartridge is not being recognised and I aminformed by the printer that there is insufficient ink in the cartridgeand a need a new replacement. The black cartridge that I have used is agenuine epson cartridge.
I have been informed by epson help linethat either I need to install a new new cartridge or that my printerneeds to go to Epson for a maintenance check.
I cannot afford another new ink cartridge nor can I afford the return charges and maintenance bill from epson.
Can you help?
0.gif Re: Epson C70 Problem by Wes t.gif (12/21/03 4:47 PM) reply + / - Theonly two option I can think of is to return the ink cartridge asdefective or you can trick the printer into accepting the cartridge.
Youwill need to download the SSC Service Utility and click on the "ResetCounters" tab and then click the "Reset Black" tab to reset the blackink cartridge. The only problem is you will need to reset or freeze theink cartridge.
You can get the SSC Service Utility here http://inkjetprinterhelp.us/epsonSSC.html
I hope this gets your printer going again.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
