If I try to start the washing machine I get no response but when I start the dryer it activate both the dryer and the wasing machine. Also it suddenly stop working and reacting at some point of the cycle. I'm talking about a Whirlpool LTE5243DQA electrical stacked washer and dryer
SOURCE: My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
SOURCE: whirlpool electric dryer will not heat
check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
the emement limit is at the top of the blower housing and will have 2 red wires going to it
the blower limit will have blue wires going to it
withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
SOURCE: Whirlpool Thin Twin washer/dryer
Check the lid switch, the machine will not spin or drain without the lid switch being activated. You should be able to see if the switch actuator is broken or missing, look in the slot where the lid's plunger drops into, if you can see the gray plastic actuator, set the machine in the spin cycle and try to depress the switch with a flat screwdriver, if it runs, the switch is cracked and needs replaced, if the actuator looks fine, and you can hear a distinct "click" when you press down on it, it may be a problem in the timer, but check the lid switch first, that's most likely the problem.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
