SOURCE: How do you install the ink roller in a canon p1 dh v
The instructions in the manual are (1) remove the printer cover by pressing down on the (triangle) mark. (2) Lift up the old ink roller and remove it (3) Insert the new ink roller by pressing it gently into position (Use Canon Ink Roller CP-16) (4) replace the printer cover. My roller has the term "Pull Up" on the left side of the roller.
SOURCE: I removed the ink cartridge from P1-DH-V and can't reinstall it!
Call Canon at 800-828-4040. Select technical support. You actually get a live person.
They can e-mail you the manual in PDF format. It takes about 5 minutes.
The manual is not available on Canon's site.
SOURCE: Settting up tax rate on Canon P1-DH III
push CA
hold TAX+ button until tax% starts flashing on the display
put in the required rate
push CA
should now be set
SOURCE: Need to find Ink Roller 2/color Canon Model #
http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
part# IR40T / CP-13
