Question about iLO IWT3206 TV
Who makes these TV. - iLO IWT3206 TV
Posted by taisha on
powersoul
    New Friend:
  • 3 Answers
Made for wallmart by ILO
ILO TVs made in China. A few brand have been connected with iLo, are Funai, Orion, Tatung
ILO customer service number is 800-289-0980 or 1-800-939-0605
ILO TV Codes. 11286 11603 11684 11990
ILO TV. 0171 1286 1990 1603 0180 1271 1963 0179 0000 1004 1000 1950 1090 1090
Posted on Jul 05, 2014
  • taisha
    taisha Jul 05, 2014
    Thank u
MY PICTURE IS GREAT,BUT NO SOUND. WHAT CAN I DO TO FIX IT?
Make sure TV is not muted.Make sure the TV is not set to SAP (secondary audio protocol)Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.If using an "S" video cable into an input on the back of your TV, these cables carry no sound, just video, so make sure you connect an audio cable too.Hook up an external device to the "TV audio out" input. This will be the test to see if it is a TV circuit board malfunction or the speakers are faulty in your TV.If you are connected to a satellite box, use the included remote and go into the "menu". Check to make sure sound settings are set correctly.
Read More: http://removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/#ixzz3lTeW6isH
Sep 11, 2015 | Televison & Video
How to reset the dvr-r box and remote when the tv is black and the same the boxes
You have an HD TV right? Has it worked before now? Make sure the cables are going into the right in and out on TV and dvr-r and make sure the cables are secure. Now make sure your TV is turned to the right setting or right channel to view dvr-r make sure dvr-r has cable/satalite cable going to in cable port and the out cable on the dvr-r is going to the TV (the port may say beside it what setting TV needs to be on to view it if not refer to your TV manual) if smart TV that recognizes new hardware unhook the port and turn TV on without it and then go see if its listed in your activity menu...if still listed try and figure out how to edit it and remove it then turn TV off hook back up and turn it back on and it should recognize it and you name it and set it all up and see if that resolves the issue. No make or model of either electronics make it very difficult to help but I hope I said something that makes sense and it works. Good luck
Dec 11, 2014 | Televison & Video
My tv says no picture
please follow the steps. God bless you
No picture
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
Sep 24, 2013 | Televison & Video
Nutec tvdvd combo
make this steps and fix it. God bless you
Jul 23, 2013 | Televison & Video
Sonic tv remote-my tv stays blank for about an hour before it shows how do i change this
follow this steps and fix it. God bless you
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Jul 17, 2013 | Televison & Video
Make tv lighter sharp 32" tv
attatch a butane cylinder to the back of the tv... add a hose to the outlet tube of the system and a self ignitor ...
VOILA , you have a TV lighter.
Mar 25, 2013 | Sharp 32C-240 32" TV
Av cable
Before plugging up any cables to your TV, look to make sure that you know the input number on the back of the tv if you have multiple inputs on your TV.
Make sure the video cable plugs into the video input on your tv, then the two audio cables, make sure they plug into the audio inputs on your tv and then make sure your tv is set to the right input and everything should be good, turn on the game system and enjoy.
Jul 31, 2009 | Sony Video Game Consoles & Games
I just setup my 42" 1080p proscan tv I have Direct tv and can not get a signal.
Okay most settop direct TV boxes go into a coaxle connector in the back of your TV witch then your Tv would need to be on channel 3 make sure channel 3 is detected by autoscanning for it or undeleting it if its been deleted but make sure the direct tv box is on and running.
If you have them on the scant connectors make sure you on the right input on your TV control there should be a input button press that to scan through to find your direct tv box!
I hope this helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 08, 2009 | Proscan 42LA45H 42 in. LCD TV
iLO IWT3206 TV Logo
93 people viewed this question
Top iLO Televison & Video Experts
Lee Hodgson
Lee Hodgson
CoppellTVRepair.com
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
