Garden Logo
A
Anonymous Posted on Jul 05, 2014
I need assembly instructions for 11 foot Wilson & Fisher Solar offset rectangular umbrella
Terry
Level 3:
  • Garden Master 11,377 Answers
  • Posted on Apr 09, 2020
Terry
Garden Master
Level 3:
Answers
11377
Questions
Helped
4620019
Points
152765
Mia Dorman
Level 1:
  • Contributor 1 Answer
Mia Dorman
Contributor
Level 1:
Answers
Questions
0
Helped
878
Points
How can I buy replacement cushions for the Wilson & Fisher Augusta patio sectional?
5 Related Answers
Anonymous
  • Posted on May 28, 2010
SOURCE: I need assembly instructions for a wilson and fish...
I didn't have my instructions either, but I finally figured it out. I do the top first. I'm 5'2" and I put it up by myself and this works for me. The leg connections are 6&5 with 6 being on the bottom with little holes near the base stand and 5 being on top. Add the corner connectors and side connectors to tops of 5. Out from the corner connectors add your 7's. Out from the side connectors the 10's for the long side and 8's for the short side. For the top corners add 4 then 3(it is that funky looking rod). In the middle connector add the 11& 12(this will be for the long sides).You will connect corner and sides with 1 (make sure to put the sliding connector on the rod with the Y's at the ends. On the top, top add the last rod. I think you'll be able to figure out how the canopy drapes. I hope I've given the right directions for yours. I put mine up yesterday.
Anonymous
  • 17 Answers
  • Posted on Jun 23, 2010
SOURCE: I purchased a Wilson & Fisher? 10? x 12? Bay
Call Wilson & Fisher and get the to send you the instruction sheets .
Can do this either by conputer or fax.
Anonymous
  • Posted on Jun 30, 2010
SOURCE: Lost instructions on how to assemble our 10 x 12
Sunjoy Industries i(866)578-6569
Anonymous
  • 1478 Answers
  • Posted on Aug 31, 2010
I will advice you check manualsonline.com to search for the manual of your device.
Take care.
gggg
  • 904 Answers
  • Posted on Mar 10, 2011
SOURCE: Please email me direct contact
Is this your gazebo shown here?
http://www.biglots.com/search/product/2610
If so, click the Download Assembly Instructions link under the description.
Base for a 11' offset umbrella
When setting up an 11' offset umbrella, it's important to provide a stable and secure base to ensure the umbrella remains upright and balanced. Here are some options for bases that you can consider:
  1. Weighted Base: Look for a weighted base specifically designed for offset umbrellas. These bases typically have a wide, sturdy construction and can be filled with sand or water to add weight and stability.
  2. Cross Base: A cross base is a popular choice for offset umbrellas. It consists of a large, X-shaped stand that provides stability. You can use weights or sandbags on each end of the base to add more stability.
  3. Cantilever Base: Some offset umbrellas come with their own cantilever base, which is specifically designed to fit and support the umbrella. These bases often have a more intricate design and provide stability while allowing for easy movement and rotation of the umbrella.
  4. Ground Anchors: If you have a solid ground surface like concrete or a deck, you can use ground anchors to secure the offset umbrella. These anchors are typically installed by drilling into the ground or attaching them to the surface.
When selecting a base, make sure it is compatible with the size and weight of your 11' offset umbrella. Refer to the manufacturer's recommendations for the appropriate base weight or specifications. Additionally, consider the local weather conditions in your area to ensure the base is sufficient to withstand wind gusts and other elements.
It's also recommended to follow the specific instructions provided by the manufacturer of your offset umbrella for proper installation and base selection.
Jun 17, 2023 • Garden
2answers
Hampton Bay 11 ft offset umbrella bent arm is stuck
The arm on your umbrella is stuck and is broken and the arm will need replacement. It would be more convenient to purchase another umbrella than to try and repair the one that is broken.
Want to replace 11' patio umbrella canopy
I have a brand new total upper 11 ft solar powered umbrella
on cape cod 5085661476
Wilson and fisher 10 X 13 pop up sun shelter instructions
Need assembly instructions on Wilson and fisher pop up sun shelter 10 ft by 13 ft by 8
5helpful
Need assembly instructions for 8x11 sun shelter
I need the instructions for a Wilson and Fisher 8x11 sun shelter
5helpful
2answers
Need assembly instructions for a 10x12 Wilson & Fisher portable gazebo. Lost instructions.
I looked for hours on the internet trying to find this.
Hope this saves you some time. The manual can be downloaded here.
You can show your appreciation by becoming my scribd follower so you can get all my do it yourself posts.
http://www.scribd.com/doc/55393964/Monterey-Gazebo
thanks
Bill Kibbe
Top Garden Experts
Jay Finke
Jay Finke
john h
