Question about Hitachi 53SBX59B 53" Rear Projection Television
Digital convergence message flashing on screen
Unable to flash focus, red curved lines at the top of screen, manual convergance will not work, problem started after a lightning storm with power surge
Ur tv now,totally have dead parts,on the tv convergence board.That,why ur flash foucus or manual covergence alignment R,G,B colors line will not matches up.The convergence board parts 2 STK convergence ICS and some or all it resistors,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-51WS510 51" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Out of alignment (red)shadow
Ur tv convergence are dead.U must know how to solder.U must have soldering tools,and solder to fix convergence problems.Must repalced 2 STK convergence ICS and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 15, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
Picture looked 3d now tv wont come on. red lite flashes 6 times.
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts down
  • TV Chirps
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 03, 2009 | Sony KP-51WS510 51" Rear Projection...
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Warning massage
I am having the same problem as well. The error message E:91:01 comes up and the flash will not operate.
Aug 14, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Samsung pcj522r
I am at a loss for what your symptoms are. Did you have a convergence issue and while adjusting your screen is flashing? Please respond to the same post each time so I dont lose any previous info. thanks
Jul 23, 2008 | Televison & Video
HOW TO FIX CONVERGENCE IC FAULT & HOW MUCH COST APPROX
Panasonic Flashing codes:
1: ----------------- +140 v.
2: ----------------- Low DC
3: ----------------- Convergence
4: ----------------- HHS
5: ----------------- IC 4011
6: ----------------- IC 4018
3 is convergence, either one of the two convergence ICs faulty, or something else (capacitor etc.) has blown on convergence board.
Jul 13, 2008 | Televison & Video
Hitachi 53SBX59B 53" Rear Projection Television Logo
20 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
