Question about Radio Shack IndoorOutdoor Thermometer with Hygrometer
How to reset FC 328F21 Weather Station - Radio Shack IndoorOutdoor Thermometer with Hygrometer
Posted by Marianne Carey on
How do i reset high temp on lacross weather station
https://www.lacrossetechnology.com/products/weather/weather-stations
Dec 25, 2017 | Measuring Tools & Sensors
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
How do I reset the time on my smartgear weather station
I have two of these and they lose the signal occasionally. Per the manual: Make sure all batteries are good and then press the TX button on the remote sensor for 3 seconds so it sends a wireless signal to the weather station. It should beep. Then on the weather station hold the CH button for 5 seconds to make it search for the transmitter until the outside temp appears. Just removing batteries and reinstalling them in various orders doesn't work. You must re-establish the wireless connection between the outdoor sensor and weather station.
Mar 08, 2015 | Measuring Tools & Sensors
I have inherited a IT-915 MHz wireless temp. station--the batteries in outside sensor were taken out but still in box-can i put them back in at this time to reset the sensor and how to set them ?
You shoud use new batteries because you dont know how old the ones that are present are. You should also use lithium battteries in the weather station sensors because they last longer and have better low temp response. The batteries should have marks on them that correspond with the marks inside the sensors.
Feb 23, 2013 | Weather Channel It 915 Mhz Solar Powered...
Reset oregon scientific weather station
I always have trouble getting mine to work after changing the batteries, but I have just managed to get it going by doing the following:
taking batteries out of main unit
putting new battery in remote unit and pressing remote unit reset button
re-inserting batteries in main unit and pressing reset button.
i think the trick is to ensure that the batteries go in the remote unit first, then the main unit after that. It has taken me days to work this out!
Jan 19, 2013 | Oregon Scientific BAR206 Wireless Weather...
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
Jul 05, 2012 | Coghlan's CTech Wireless Weather Station...
WMR928NX battery replacement
I have an Oregon WMR928NX weather station. I have replaced the alkaline batteries in the wind and rain sensors. These did not communicate with the main unit, so I reset both units but only the wind sensor communicates. I have checked both battery voltages on the cuircuit board and both are correct, I don't know a solution. Thanks Rob
Nov 23, 2010 | Oregon Scientific Cable Free Weather...
Radio Shack IndoorOutdoor Thermometer with Hygrometer Logo
207 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
