Try connecting wires from a good battery of equal voltage, simply connect the negative side of each battery and the positive sides( A butter knife on the bottom and one the top will do). If the battery is larger or smaller the a piece of coated wire with the ends stripped off may be necessary for the top connection. This is parallel circuitry. Make sure the battery is removed from unit !!! This will give your battery a flash charge that might just get the job done.
Zynga Poker sent you an email regarding possible unauthorized access to your Facebook and Zynga Poker account. This email was sent to [email protected]. We recommend changing your Facebook password immediately.
Please verify your account by carefully following the instructions in the email. Click here to resend email.
Email the manufacturer directly at [email protected] They may be able to send you a copy in the mail or via email that you can print out. Also, here is their address and phone information. PO Box 459 NEWBERG OR 97132 Tel: (503) 538-3100 Fax: (503) 538-7012
