Question about Vector Spotlight - 1 Million Candles Power, Model# VEC127Y
What is the batery voltage for a vector vec139S.
MY 350 amp Black and Decker Jump Starter's battery is bad, replacement
They all have the same gray battery in there... but first connect it to the car batery while the car is running for about 30 minutes and see if the battery charges. The little cjharger you have could be not doing a good job...
Apr 19, 2014 | JUMP START SYSTEM
How do i fix the swich of my vector light batery gets charging but the on and off swich do not works
Self help isle at your local auto parts store should have something close. You may have to remove the switch and take it with you to compare.
Dec 27, 2012 | Camping, Backpacking & Hiking
WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
Mar 27, 2012 | Vector 1 Million Rechargeable Spotlight
Looking for a dmu 6-6 battery
Batteries inc stores (if you have one in your town) or their website, can replace almost any battery Vector uses. You dont need the model number of the battery or spotlight, just give them the old battery,
OR if working by website, give them: the dimensons of the battery (h, w, d,), the voltage, and the amp hour rating. They will find one that is the same voltage, close to the same dimensions or a little smaller, and close to the same amp hour rating. The only thing that must be exact is the voltage.
NOTE: there are many websites that sell lead-acid batteries, I have personally used batteries inc. at www.batteries-inc.com
Nov 23, 2009 | Vector 2M Pwr Rch Spotlight
Everything works but the jumper cables
Most likly the battery is old and will not keep a charge. I just replaced my battery for about $50 a few weeks ago. Go to a story like Battery + for a replacement. It worked for me.
Jun 09, 2009 | Vector VEC010S Jump Start System 300 Amp...
Dead battery
It depends on what voltage the internal battery is. If it's a 6 volt, the charging voltage will be a little higher, close to 6.5 to 7 volts. Most of these spotlights are 6 volt. New batteries can be found at Battery International: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Mar 13, 2009 | Vector 3 Million Candlepower Rechargeable...
Looking for replacement parts for vector spot light
The bulb you are looking for to fit these vector spot lights is an automotive bulb, and H3 with a PK22s base. They come with a cable and a nickle size disk at the base of the bulb. They come in several wattages, eg 55w and 100w. Try the "bulbs.com" website, in their search box type "H3 PK22s" and you will see they have a variety of wattages and voltages. Be sure you buy a 12V for these spot lights. They come with a cable and nickle size disk at the base of the bulb. Hope this helps. From Uncle Ray
Oct 06, 2008 | Camping, Backpacking & Hiking
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Vector Spotlight - 1 Million Candles Power, Model# VEC127Y Logo
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
