SOURCE: smith corona xd 7000
You might have blown a fuse...you will have to take the top covers off to see the fuses....otherwise the transformer has overheated and needs replaced.
SOURCE: Smith Corona XD 6500
You might check the outlet to make sure there is 120V. Otherwise there is a good chance the power supply has burned out. Also the cover has to be down, and there has to be a ribbon mounted properly for this machine to work.
SOURCE: We have an older model. it's the XD 6700. The
there is a contrast dial to the right of the display, try that when the mach. is turned on, otherwise you have a bad display, connection or main board, all of which would make it cheaper to buy a new mach. than to repair
