Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Where is the power strip in a weiser combination Lock
3 Related Answers
VtToolMan
Mark
  • 704 Answers
SOURCE: Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
papouducafe
  • 15 Answers
SOURCE: Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
Posted on May 15, 2011
Coaltowner
  • 963 Answers
SOURCE: need to change the combination
Follow this link:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Which will take you to the programming instructions for your Powerbolt 1000.
Posted on Jun 27, 2011
How do I enter new code?
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Nov 26, 2015 | Weiser Lock Locks & Locksmithing
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
Sep 21, 2012 | Weiser Lock Powerbolt 1000 Lock
Our Powerbolt 1000 started beeping this morning. I've tried replacing the batteries and disconnecting the power strip. The beeping continues. I am unable to reset the code. Are there any other...
Powerbolt is Beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug power strip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
Since you've already gone through the battery change, etc.,this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense.
Also, they will be able to get the correct part on order for you.
Jul 16, 2011 | Weiser Lock Powerbolt 1000 Lock
I have a weiser combination lock and it seems to be bogging when keying the comb. in so i recharged my batteries and installed back into the lock and it still bogs. Is there one batterie better than...
Weiser has a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Jun 28, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Need to change the combination on weiser lock
Follow this link:
Jun 27, 2011 | Weiser Lock Powerbolt 1000 Lock
The combination won't open the lock ...it takes 4 or 5 times to open the dead bolt all the way ...sometimes on the first try but mostly 5-9 tries .
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Sep 29, 2010 | Weiser Lock Powerbolt 1000 Lock
Jul 09, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Need to change combination
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Jun 01, 2010 | Weiser Lock Powerbolt 1000 Lock
I need to change the combination
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
Jan 07, 2010 | Weiser Lock Locks & Locksmithing
May 02, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
150 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
