Dripping inside good downward angle, cleaned drain still dripping inside,any other options
SOURCE: water is dripping from inside
Window AC's mut be installed with the back slightly lower than the front to allow the condensate (water) to drip outside
SOURCE: Have 5000BTU Goldstar window unit. Water dripping
the bottom of the case from the outside usually has a "divot" in it below the coil to allow flow from the hose that runs across the bottom of the unit, try pressuring up and "blowing out" any obstruction, if this does not work then you may have to disassemble the unit and verify the drainpan is not cracked below the indoor coil (rare)
SOURCE: where is the drain hole
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
