Question about Sharp Office Equipment & Supplies
What is maintenance code of DC on Sharp 3100N
MX 3100N has a maintenance code of DC. What does it mean and how to fix it?
Collin Grimes
    Guru:
  • Sharp Expert
  • 62 Answers
This is a scheduled maintenance programmed into all of these machines. It pops up when the machine crosses a certain "milage." If your machine is still making nice copies and prints it's nothing to worry about.
Copier Collin Houston TX Copier and Imaging Expert
Posted on Feb 10, 2015
5 Related Answers
Anonymous
  • 267 Answers
SOURCE: What is error code 5000 for sharp mx-3100n
HI,
this will help you out...
http://www.afoffice.com/sharperrorcodes.htm
thank you,
vijay(vote for me)
Posted on Sep 24, 2009
Testimonial: "Many thanks"
Sayed Mahmood
  • 3 Answers
SOURCE: Sharp MX 3100n showing code H5-01 , what is it,how
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Posted on Feb 20, 2010
unkl foddy
  • 120 Answers
SOURCE: Our sharp MX-3100n printer is
Apparently your machine is set to stop when the supply counters trigger a maintenance code. You can type # * C * and go into Sim 26-38 and bypass this.
VC means your cyan developer has reached its' rated life of 60,000 copies and needs to be changed. Your yellow and magenta developer which are usually changed at the same time as the cyan have also reached their end of life (VM, VY) and so all 3 will need to be changed (not black, your VK code will come up at 100,000).
You will need the color developer kit and the seals and filter. Sim 24 resets the counters and sim 25 resets the toner-developer mix ratio (this is MANDATORY or your new developer will be ruined, you must run the copier with a door open and only close it when you are ready to set the mix).
There's also various color calibrations after this you can get from a service manual. DO NOT run old developer through your machine, it will eventually lose its' magnetic properties and be carried through the copier sandblasting everything in its' path.
Posted on Feb 24, 2011
Mark Drye
  • 24 Answers
SOURCE: SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Posted on Aug 31, 2011
lilgto64
Matt Wolanski
  • 3 Answers
SOURCE: Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Posted on Oct 11, 2012
My sharp color copier Mx 3100n is indicating F2-73 after using 88-1 how do I restore it
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
Jan 08, 2017 | SHARP MX-3100N
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Feb 26, 2015 | SHARP MX-3100N
How to fix the sharp MX-3100N printer? the message on the screen is install the developer.
Developer unit is not detected , or developer is depleted ( which is very bad , because it could mean that it spilled inside your copier , it is very abrasive)
try removing and re-installing the developer unit , and maybe try using another unit for control,
could also be your harness, see if plug of developer unit is plugged into mainbord
Feb 23, 2015 | SHARP MX-3100N
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Dave.
Sep 25, 2014 | Sharp Mx-3100n Color Copier Super...
Sharp mx 3100n
Sounds like PJL = Printer Job Language Set source Color Convert. whatever that means !!!!
Sounds basic but have you checked the Manual ? http://www.manualsprinter.com/sharp-mx-3100n
Go through sending test prints and go from there.
Aug 25, 2014 | Office Equipment & Supplies
What does error code dc on sharp 3100n mean?
image cartridge cyan need to be replaced
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 04, 2014 | SHARP MX-3100N
Anything try
Which windows platform.
Jan 28, 2014 | SHARP MX-3100N
Aug 28, 2011 | SHARP MX-3100N
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
1,463 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
