Question about Masterbuilt 20070106 Electric Smoker
Temperature guage is stuck at 300 degrees - Masterbuilt 20070106 Electric Smoker
Coolant temperature sensor location on 97 ford expedition
I believe they are located in the intake manifold somewhere. Make sure the one that tells the computer the coolant temp is ACTUALLY giving out the correct temperature. I had a bad one one time in a 1993 Ford F-150, 5.8L....... no check engine light came on but hard to start. The bad sensor was telling the computer it was 32 degrees F when it was almost 80 degrees outside.!!
Garbage in=Garbage out.
Here is a video link from Youtube. There are 2 sensors, 1 for the guage and the other tells the on-board computer how hot/cold the coolant is. The one for the guage has 1-wire and the other one has 2 wires.
Hope this helps, ask more if you need to. What kind of problem are you having? No heat inside? Guage needle not getting into the normal area?
1997 Ford Expedition 5 4L V8 Triton Engine Coolant Temperature ECT Sensor...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2496c4f07ad24453
Oct 20, 2015 | Ford Cars & Trucks
Normal running temperature
I would look else where for the problem unless the thermostat is stuck open. Thermostats work by blocking the water to the radiator until the coolant in the block has reached operating temperature and then they start to open. As soon as they read a cooler water temperature they will start to close and restrict the flow until the operating temperature is maintained . IT would make no difference which thermostat you fitted as the number indicates when it starts to open. I would be checking the temperature sender unit and the gauge and I would be checking the coolant level in the radiator at the cap not the resevoir
Oct 30, 2013 | 2005 Chevrolet Monte Carlo
Please, tell me what temperature suppose to be in ref. and freezer compartments.
Hello Leo.
The general rule is 0 degrees F in the freezer, and 40 degrees F in the fresh food section. The temps are best measured with a temp guage in a liquid. Digital guages are usually more accurate than analog. But, use what you have available, and if you can't quite believe the readings, ie ice cream is frozen, milk is good and cold, then move up to a better temp guage. Or, if you have two or three different ones, put them all in there and use the average.
If you think temperature adjustment is necessary after testing, make it very small and wait for a day to take another reading.
Hope that helps you.
fil
Mar 03, 2011 | Dacor Epicure EF48BDCB Stainless Steel...
Temperature guage doesn't work and heat blows cold
Check the thermostat.It sounds as though it's stuck in the open position. Fuel comsumpion increases as well.
Nov 24, 2010 | 1994 Toyota Tercel
Inside temperature guage has stopped giving A correct reading it is stuck on 68 degrees. Started last week. Any ideas on what could be causing this problem?
Taking out the gauge cluster and having a look at the gauge would be recommended, it might be the gauge motor either stuck or burnt, you might need solder another motor ( they are very small motors, moving gauges up and down).
Jun 23, 2010 | 2001 Dodge Durango
I have a 2005 Jeep Grand Cherokee. My problem is that my C/T guage reads about three degrees higher on the outside temperature side than the actual temperature is. I realize that might be a minor problem,...
Are you talking about the coolant temperature (c/t) or the ambient temperature (outside temp). If you're refering to the ambient temperature the problem is the sensor is located under the radiator support and picks up the temperature off the pavement this is done intentionally to help detect icing conditions and unfortunatley there is no calibration for the sensor.
May 14, 2009 | 2005 Jeep Grand Cherokee
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
Masterbuilt 20070106 Electric Smoker Logo
415 people viewed this question
Top Masterbuilt Grilling Experts
Paul Carew
William Miller
William Miller
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
