M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.
1-Press utility button on panel.
2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.
3-its the code to get into service mode.
4-After pressing above mentioned buttons you will enter into service mode.
5-Now select service choice option.select it by pressing OK button.
6-In service choice option you will see Maintenance count option.
7-Select it by pressing Yes or OK button.
8-There will be three options 0,1,2.
9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
SOURCE: konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
