Check your Windows label that has the product installation code printed on it. On the label it will also have the XP version number it will be X08, or X10 or X11 etc. You can use any Windows XP installation CD PROVIDED the CD Part No. matches the X08 or X10 or X10 version that is printed on your product label. If you install XP using the wrong version CD then the installation process will not accept your product installation code and Windows will not install.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
This is older machine model and drivers are made only for UNIX and SAP/R3 you can try and test does will work with this drivers because and this are open source.Here you are link and select " Choose other OS " http://support.ricoh.com/bb/html/dr_ut_e/re1/model/mp15/mp15.htm
