Sounds like disc is bypassed. The refrigerator will not work on LP or electric without 12v power. The 12v power is supposed to go through the disc as a safety fail safe measure to prevent fire. Follow the 12v power from the plastic junction block. It should go behind the burner as a red wire with a black sleeve. Located in the black sleeve is a diode. From there it should go to the thermo switch and from the switch to the circuit board. If the 12v power goes straight from the connector block to the board then the safety recall has been bypassed and must be reconnected. The recall is a free kit offered by Dometic and your local RV dealership should be able to install it for you.
