A Speed Queen top-load washer making a banging sound at the beginning of the cycle could be a sign of a few problems. You could examine the following:
Size of load: Check to see that you are not overfilling the washer. The water and clothes should be about 3/4 full in the washer. Overloading the washer can result in the drum becoming unbalanced and making banging sounds.
Leveling: Verify that the washer is level. If not, reposition the washer's feet until it is level. A washer that is out of balance can also make banging sounds.
Spring elements: Examine the suspension springs at the drum's top. The drum may slam against the washer's sides if one of them has broken or come loose.
Motor: The motor might be the source of the banging sound. The washer may vibrate and make banging sounds if the motor is loose or damaged.
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
The bang you are experiencing sounds to me like water hammer when a valve is shut off very quickly. It very well could be the check valve slamming shut.
It sounds like you your dryer may have a bad Blower Wheel, which is causing the banging noise that you are hearing (especially if the banging noise continues for a few sections after you turn your dryer off).
When I was researching which washer to buy I read that this one is not the best choice to have on a second floor. Ours is on the main floor and can still be a little loud in the spin cycle. Have you balanced the machine properly? Otherwise, I think I read that people have had success putting a thick, dense rubber mat (like a stall mat for horses) under the washer to minimize the sound/wobbling. Good luck!
Patty
try to put other soundcard...ur test ur sound card on other pc...then try to install the driver ther and check if it ok...if that will we ok on other pc so it means just a drier problem on your pc
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
