If the light on the front of the remote blinks only one LED you have to replace the battery's, sometimes even new battery's lose charge overtime if they are not stored in proper conditions.
Insert a Wii Balance Board compatible game disc in the Wii console.
Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
Open the small SD Card slot cover on the front of the Wii console.
Remove the Battery Cover on the bottom of the Wii Balance Board.
Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
The blue light will stop blinking and stay on steady once the syncronization is complete.
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
Press the Power button on the Wii console to turn it
on.
Open the SD Card Slot cover on the front of
the Wii console.
Remove the battery cover on the back of the Wii
Remote you
wish to sync up.
Press and release the SYNC button on the inside of the SD Card
compartment
on the console. Press and release the SYNC button just below the
batteries
on the Wii Remote.
When the Player LED blinking stops, the syncing is complete. The
LED that
is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
You have to sync! To Do This Open The SD card Cover to reveal the red button. Press it and hold the red button on the Wii remote (under the battery cover). May take a few tries. Hope I helped! Lady Gaga <3
You need to re-assign to the Wii. When you first bought it you pressed the button on the front of the Wii to configure controllers, then the controller buttons to find the Wii. When you change batteries you need to repeat this process as the 'memory' of the controller to the Wii has been wiped
Sounds like it's not synchronizing with the infrared bar. That might've come loose. Double check to make sure that's plugged into the Wii. If that's not connected the Wii Remote will not stay on because it's not connecting.
