LOOKING FOR CODES TO USE ct-90126 remote ON MY PHILIPS 42" FLAT SCREEN TV
SOURCE: remote codes for toshiba ct-90157
Samsung 061, 062, 086,090
here is a link to your manual:
http://remotes.com/remotes/documents/Toshiba/CT-90157.pdf
SOURCE: need codes for ct 90157 remote for phillips dvd player.
I bought a TOSHIBA 52RV530U HDTV, and am currently unable to control my Philips DVP5960 DVD Player with it. But the Philips control codes I see in the manual (which may be of use to other owners of Philips devices) are: 026, 031, 044, 057 ...oh HEY now i see those are only for Philips VHS machines.
Philips DVD player codes are: 004, 051. At least as of 2008 when the TV manual was published.
SOURCE: what is the remote code for PHILIPS DVP5990
I'm using the GE Universal Remote, and found that the four digit code 0914 worked.
SOURCE: codes for toshiba universal remote number ct-90302
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
