Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Diagnostics mode on fisher and paykel dishdrawer
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Fisher & Paykel Dishdrawer DS603
2 quarter sized circles on either side of drawer will release the drawer fronts and allow acess to the electronics, behind the bottom drawr taped to back wall of unit is a troubleshooter/techsheet which might prove to be very helpful
Posted on May 02, 2008
Anonymous
  • 145 Answers
SOURCE: Top drawer Fisher & Paykel Dishdrawer no lights lcd
Your original problem, F4, was the machine trying to tell you that the heater plate was not working. When you turned the drawer up-side down, you may have damaged the wiring harness. If you do get a technician, call a fisher paykel authorized servicer, not an independent, and make sure you tell him about the F4 problem. A new problem has been introduced by the cleaning procedure, and both issues will need to be resolved.
Posted on Dec 11, 2008
Anonymous
SOURCE: u3 code on fisher paykel dishdrawer how to reset?
This site tells you how to reset:
http://applianceguru.com/forum1/163.html
I have the same issue and will try this tonight to see if it helps.
Posted on Feb 18, 2009
Anonymous
SOURCE: Change Fuse on Fisher Paykel Dishdrawer
I have a single drawer F&P dishwasher. This morning a safety switch trigged. This afternoon when I went to use the dishwasher found that it had no power. There are no lights and there was a smell of something burning. The power outlet has power. Can you help?
Posted on Feb 14, 2010
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
F 2 on fisher paykel
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/590199D%20DishDrawerP7%20userguide%20USCANZAUGBIE.pdf
More then likely you will have to remove both drive impellers and give them a good clean as well as the stainless strainers . Every month or so I run a rinse cycle through them with a cup of white vinegar . this also helps with the damp smell in the warmer weather.
Good luck
May 04, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Fisher paykel dishdrawer keeps beeping with f1 error
http://www.scribd.com/doc/6462163/DD601V2-Manual#fullscreen
Nov 17, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Fisher and Paykel dishdrawer ds601
when it is beeping is there any code on the screen such as F1? (if not a screen model there will be a sequence of lights where u select the cycle) also can you hear the drain pump running nonstop till you turn it off at the wall? when you get back to me ill run you through getting into the diagnostics and test cycle program to check all the components, but from the sounds of it you may have a leak causing the flood switch to trigger
Nov 10, 2011 | Fisher and Paykel Dishwashers
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Michael Thomas
Michael Thomas
Paul Bade
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
