Question about GE Security Simon 3 Wireless Home Security System
How do I change the phone number that my ADT security system calls when the alarm is triggered
How do I change the phone number that my ADT security system dials when the alarm system is activated.
2 Related Answers
hswmoore
  • 3 Answers
SOURCE: GE/ADT DIY system will not accept master code./beeps twice/2 hour
Press the system status button on the top right and the system should announce the error message that is keeping it from accepting the code.
Posted on Apr 26, 2010
Bill
  • 39 Answers
SOURCE: How do I change the phone number that my GE Simon
Open the front cover, enter the installer code and "add" the new phone number in "Option 4" as the Primary phone number. "Option 5" is the secondary phone number location on the Simon 3.
Posted on Aug 25, 2011
Alarm system how to change arm and disarm code on ADT safewatch plus RF
If you dont have user manual download one from adt website you might have to register for security reason
Oct 03, 2017 | Home Security
To turn the beep sound off when system is set to armed
Troubleshooting FAQs - Solve Problems Quickly by ...
www.adt.com/help/faq/troubleshooting
The ADT CorporationHow do I silence low battery beeping? ... Why is my ADT Pulse security systemreceiving an unavailable message? ... How do I fix a disconnected camera? ... by a motion detector while the system is armed, the burglary alarm will sound. ... Some common events that may cause a motion detector to set off a false alarm ...
Five Steps: How to Stop a Beeping Security System
https://www.vectorsecurity.com/.../Five-Steps-How-to-Sto...
Vector SecurityFeb 9, 2015 - The shrilling sound of a continuously beeping security system is enough to drive anyone crazy. A power outage, faulty wiring or bad batteries ...
The Top 15 Questions about ADT Home Security Systems ...
zionssecurity.com/...security/the-top-15-questions-about-adt-home-securi...
Oct 10, 2012 - How do I turn off the voice descriptions but keep the chime sound on?... If your time on the Lynx system is not set all you need to do is push your user code + # + 63. ..... When our security alarm is not armed it beeps every few seconds ....Reasons to Install Security Cameras in your Home ยท Small Business ...
Jan 03, 2016 | Home Security
Vonage and ADT
Does the ADT system use a phone line to call into a local police department or security team? What do you mean by parallel phone system?
Dec 04, 2011 | Home Security
How do I change the phone number that my GE Simon Security System calls when the alarm is triggered?
Aug 21, 2011 | GE Security Simon 3 Wireless Home Security...
Alarm beeps every 5 mins. I have changed battery and problem still persists.
Tell me what brand your alarm is and I can help you with the beeping. Usually if you hit # it will silence the beeping for 24 hours. Something you can try is finding your main control box. Its usually located in the garage or in a closet. It is tan and 6 x6. First disconnect the battery inside the control box by jiggling off the black/red leeds. Then unplug the power supply. Wait five minutes. Reconnect the battery and plug in the control box. This is completely powering your system down and then repowering it up-essentially "re booting." If this does not correct the issue, give me the brand and I can further help you.
Nov 22, 2010 | Industrial Home Security Burglar Alarm...
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
We just moved into a house and it has an alarm system that has westinghouse on it. There are sensors on every door and window down stairs. We have no idea how to turn it on and get it set up.
Call an alarm company like ADT. If they can use it they will. it will require some minor reprogramming and they will check all sensors, if the use it. 1-800-ADT-ASAP.
Feb 01, 2010 | GE Security Simon 3 Wireless Home Security...
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
Alarm messes phone system
It sounds like your alarm is picking up the phone. How many rings before it picks up?
Mar 18, 2009 | BellSouth BELL SOUTH CI-36 Caller ID with...
GE Security Simon 3 Wireless Home Security System Logo
202 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
