SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
thanks.
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
SOURCE: I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
SOURCE: sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Testimonial: "Thanks! That does help. Now I'll have to find your tip on Adjusting Tension =)"
