Question about HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 wont network - HP LaserJet 3055 All-In-One Printer
5 Related Answers
thetechgeek
SOURCE: HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Posted on Feb 19, 2008
Anonymous
  • 105 Answers
SOURCE: How to reset an HP LaserJet 3055
If you go in your user manual to page 241, it shows the following instructions on how to reset the printer to factory defaults. One important note is that you will lose EVERY stored piece of information including phone numbers and such.
To restore the factory-set defaults
1.
On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Service, and then press .
3. Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
Hope this does it for you.
Posted on Jun 19, 2008
sachin gaiki
  • 61 Answers
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Posted on Jul 24, 2008
Anonymous
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
Posted on Mar 23, 2009
Anonymous
  • 102 Answers
SOURCE: HP LaserJet 3055 scan over network.
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Adf jam hp laserjet 3055
Here is a link to view or download the Service/Repair Manual. It details how to tear the whole thing apart if you need to.
Laserjet 3055
Sep 17, 2009 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Scanning from the network
Dear Friend,
Install the printer driver on your computer and than download fix scan utility from Hp.com. After installing fix scan utility You will be able to scan.
You have to do the same on every computer from where you want to scan.
Regard
Under Trainee
Dec 17, 2008 | HP LaserJet 3055 All-In-One Printer
Envelope Formating Using Word 2003 & HP Laserjet 3055
The problem occurred when I used network but not direct connection. It turned out I had the wrong driver for the network connection. I learned this through HP's online troubleshooting tool.
Sep 30, 2008 | HP LaserJet 3055 All-In-One Printer
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3005 wont install on HP laptop
HP director? the admin utility. most likely yes...Photo viewer, most likely NOT...are the 3 that can't set up differently(permissions) than the other five?
Feb 26, 2008 | HP LaserJet 3055 All-In-One Printer
Hp 3055 all in one
ok DO check my link to setup the network
http://www.fixya.com/support/t391229-hp_laserjet_3055_network_connection
thank you
Dec 14, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
112 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
