SOURCE: installed drivers and set up new unit per instructions,unit will not scan or print from any user
open the nprinter folder and confirm that your preinter is set as the default printer,try and print a test page,then send your printing jobs,good luck. eyo7 [email protected]
SOURCE: when display "84 replace Photoconductor"
Turn printer off. Press and hold the right arrow and checkmark. While holding, turn printer on. Hold button combination until small clock appears on the screen. Once menu comes up, select the Reset PC count. That will fix your issue.
SOURCE: my lexmark c532dn printer when printing a coloured
it shows that yellow and magenta colors gone end, need re-fill or replacement.
hope it helped, if so rate the solution
