Question about Bulova Marine Star 96C30 watch
How to set time on bulova 96c30 marine star - Bulova Marine Star 96C30 watch
Posted by Mason on
andrias
    Master:
  • 443 Answers
Try here
Posted on Jul 04, 2014
I can't set my watch.The book that came with it doesn't match my watch.Thanks
I have looked at thier web site and can't find your model listed.
I suggest you go to their web site and find your nearest service center and bend their ears about poor service. T
hey should be able to give you a set of instructions that suit your model, after all, they must have issued such instructions at some time and they should be able to dig them out for you
Mar 15, 2011 | Bulova Marine Star 96C30 watch
My hands will not synch up with the time zone. it seems like they are 6 hours off. I also lost my instruction manual
Go to http://www.bulova.com/brands/bulova/product.aspx?origin=collection&sku=96B113&brand=bulova and look at the list of Marine star watches but not the model you have.
I suggest you look through the models the show and select the one that looks similar to yours and click on the watch to get details, which should include operating instructions.
Sep 26, 2010 | Bulova Marine Star 96C30 watch
How to change the time on Bulova Marine Star 100m. This is an old watch with 4 stems. 2 on each side. One is an on/off stem which is on the right side of the face.
1st: make sure the watch is set to "tme" , the botton dail display, press bottom right stem
2nd: pull out the bottom right stem ,
3rd: press the left top stem for increase time . i.e. 2:40 pm to... 2: 45pm
4th, or press the left bottom stem for decrease time: i.e. 2:40pm to .. 2:30 pm
5th: once time is good, then press in the right bottom stem,
May 03, 2010 | Bulova Marine Star 100 Meter Stainless...
Need operators manual for a bulova marine star 90A07
While I can find "Marine Star" in the list of models, I could not find one with the same refernce number.
There are a number of models so if you go to http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine%20Star&gender=1 ", you may be able to find one that looks like yours.
If you click on a watch, details appear and these include operating instructions.
Apr 11, 2010 | Bulova Marine Star 96C30 watch
I need a manual to operate a bulova 98G70 marine star wrist watch
Copy "http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine%20Star&gender=1" into your search engine and you should arrive at the Boluva web site page listing Marine Star models.
I couldn't find your particular model but perhaps one of those listed is similar to yours.
Mar 19, 2010 | Bulova Marine Star 98G71 Wrist Watch
Setting time on 96g36 can you help have no manual at all
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all watch manuals. Rate me, plz.
Feb 24, 2010 | Bulova Marine Star 96C30 watch
I havent worn this watch for about a year the battery has 10 year warranty and was working fine.now it has stopped working.
A few watch companies...Bulova being one of them used to give a 10 year warranty but I dont know of any batteries that actually last 10 years! The average life of a 1.5 volt silver oxide battery is 2-3 years (sometimes a smidge longer) depending on the age and condition of the watch. A 3 volt lithium battery will get on average 3-4 years.
Im guessing that your battery is probably dead! :-)
Jan 18, 2010 | Bulova Marine Star 96C30 watch
My watch has stopped working and the battery is fine
The battery may be bad or installed with the wrong side up. Usually the positive (+) side faces up.
If this is not the problem you may have a bad coil in the movement or the watch needs servicing by a qualified watchmaker.
If you have any further questions please let me know.
Many thanks!
Mike Kenley
TimeOut
Worldwide watch and clock services
If it don't tick I can fix
Jun 01, 2009 | Bulova Marine Star 96C30 watch
How to set time on a bulova marine star 96C30
For some reason you cannot find the manuals on the Bulova web site any longer. But don't worry....
I have the manual for the Bulova Marine Star 96C30 Watch. This is easily fixable.
Below, I have typed the instruction on how to fix this issue as well as reset the time and calendar and a few extra tips in case you forgot....
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right). The "B" button is at the 10 o'clock position (upper left) The "C" button is at the 8 o'clock position (lower left) The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET 1. Pull the "M" button out to the setting position. 2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING 1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window. 2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise. 3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24". 4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons. 5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete. 6. Reset the time, calendar and other modes.
To set the time. Note that changing the time in any of the cities will automatically update the time for all the cities. 1. Press the "M" button to move the mode hand to (TME) 2. Press either the "A" or "C" button to move to the desired city. 3. Pull the "M" button out to the setting position. 4. Press the "A" button. SECONDS will blink. Set them with "C". 5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button. 6. Press the "A" button again, and HOURS will blink. Set with the "C" button. 7. Press the "A" button again, and 12 or 24 hours tim format will appear. 8. Push in the "M" button to its normal position.
To set the calender 1. push the "M" button to move the mode hand to (CAL) 2. Set the city using the "A" or "C" buttons. 3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month. 4. Push the "A" button. The date (day) will flash. Adjust with the "C" button. 5. Push the "A" button. The YEAR flashes. Adjust with the "C" button. 6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands: 1. Press the "M" button until the mode hand is in (TME) or (CAL) mode. 2. Pressing the "A" and "C" button together. The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps.
Feb 23, 2009 | Bulova Marine Star 96C30 watch
Bulova Marine Star 96C30 watch Logo
400 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
