My summit spwd1800 gives me error code 1 can not look door, how can i fix this?
Posted by gertrud manes on
andrias
    Master:
  • 443 Answers
Your locking clamps on the door and door well are probably out of alignment a switch censer in side is out of place so my best bet is to take it to a repairer
Posted on Jul 04, 2014
I am receiving an "error 7" for my Summit SPWD2201SS washer/dryer combo. What does this error mean?
I could not find a manual for your SPW2201SS, but I did find a manual for a SPW2200SS. (Look for clogged hoses, in and out!) Sadly it only lists three 'error codes' on Page 27 and they include: E10 E21 E31 Summit SPWD2201SS Washer download instruction manual pdf
Oct 28, 2018 | Summit Washing Machines
Summit error code F1 ..what problem
Shinning, Unplug your appliance,wait 10 minutes and plug back in to see if error goes away. F1 could mean a defective touch control pad. You may have to find a good repair Tech. to diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix an F1 Error On Kenmore or GE Range
Range Stove Fault Codes
What does the F1 error code on an Amana oven model number AOCS3040ww mean...
Summit Commercial TTM7212KW WTM7212KW Gas Single Oven f1 beeping Questions
Jul 12, 2016 | Kitchen Ranges
How to fix trouble code 0910
Unrecoverable error (The count is made by C-5402.)
An abnormal operation accurs when an interupt copy is made (copy print job 1). Estmated defective par Overall control board (OACB).
Oct 15, 2014 | Konica Minolta Office Equipment & Supplies
What is the error 1 sign for my summit spwd 1800
It means something is wrong with door lock mechanism.im currently having same problem.
Jul 05, 2014 | Summit SPWD1800
Dryer proplem
Rather than try to give you answers, I'm giving you this online link that COULD lead you to a solution: http://appliantology.org/topic/42011-washer-dryer-combo-error-code-er13-haier-summit-ariston/
I looked at it for a few minutes and answers are up and down between encouragement and discouragement. One suggestion is a bad thermostat at the top of the unit, but I'm not sure if you'll be successful in locating replacement parts according to some of the things I glanced at. Hope this helps.
Jun 28, 2014 | Summit SPWD1800 24" Washer/Dryer Combo...
How to fix a EHE error code
1. Start the drier normally
2. Before the "EHE" error appears, open the drier door!
3. Because the door was opened during program, "dE" error is shown
4. Close the door and press "start/pause" to continue
5. Program will continue normally; problem fixed!
Apr 30, 2014 | LG WM3431 Front Load Washer / Dryer
What is meaning of this ATM error
*7810*2*E*300050900,M-13,R-10110
what is meaning of this error codes and whats happening for atm machines
Jul 19, 2013 | Summit Appliances Division Youniverse...
1995 eagle summit "Check engine light"
Hi
I know on the Talon model, if you cycle the ignition switch ON OFF ON OFF ON within 5 seconds, then the power loss/check engine light will flash out the ALDL trouble codes with a 4 second pause in between each trouble code as follows:-
lets say for instance trouble codes 23 and 45 were stored. They would be displayed like this:-
lamp illuminates for 2 to 3 seconds as a bulb check then goes out
lamp then flashes 2 times, pauses, then flashes 3 times
4 second pause
lamp flashes 4 times, pauses, then flashes 5 times.
Worth a try?
Regards
Geordie
Jun 12, 2008 | 1995 Eagle Summit
Washing Machines Logo
317 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
