They are both correct. If you ever need supplies for it, and want to save money, give me a call or shoot me an email. 818.700.7419, Damien @ iPrint Technologies - [email protected]. Have a great day!
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
SOURCE: 57.70 error for hp colorlaserjet 9500n
1. The cooling fan in the optional duplexer is bad.
1. Replace the duplexer fan.
from hp repair manual
this is the fuser fan error replace them ur problem will be resolved
SOURCE: i have hp laserjet cp5525 when i switch on printer
Low fuser temperature and fuser warm-up failure
Items 1 and 2 you should be able to do.
If printer is still under warranty...use it. Call HP.
1.
Remove and then reseat the fuser. Make sure there is no residual paper in the fuser. Make sure the
device is not located in front of a vent or window where cool air may interfere with the ability of
the fuser to heat up.
2.
Check the product power source. Make sure the power source meets product requirements. Make
sure this is the only device using the circuit.
3.
Replace the fuser.
5.
If the error persists, replace the low-voltage power supply.
6.
If this product has been previously serviced, check the connector (J131) on the DC controller PCA
and the connectors (J109 and J110) on the power line between the low-voltage power supply
assembly and the fuser.
If turning the printer off and on again
does not resolve the 59.00 or 59.A0
error, remove and reinstall the image
transfer cleaner.
Post back if this does not resolve the error.
