Kenwood KDC-MP435U CD Player Logo
S
Santosh Fakira Posted on Jul 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u add usb to bmw radio - Kenwood KDC-MP435U CD Player
andrias
Level 3:
Master:
  • Master 443 Answers
  • Posted on Jul 04, 2014
andrias
Master
Level 3:
Master:
Answers
443
Questions
0
Helped
66633
Points
1021
A electronics tech can help you out there like a place that fixes TV's and radios and stuff
Hello. How do I code my 2004 BMW Professional radio with factory fitted USB and AUX. My vehicle is a 2009 production
I'm not sure whether the two will be compatable , best go to a auto audio specialist, they will know straight away if possible
How do you reset immobilizer bmw e38 740i
0025 says code on dash display try enering 0000 or 1234. If still problematic add last 4 of car's VIN number by using car's radio example 5578 code would be 0025. Hope this helps. I am no expert but I have rebuilt my engine myself and replaced vanos timing rails. Best of luck.I hope this day
Radio
You can use this BMW 12Pin USB SD MP3 Adapter to solve the problem,hope help.
Bmw bavaria rds
Margaret, this is free public forum , demands don't play here (free)
and you double posted. why do that.? if you wish to elaborate
try posting below 1st post, as an add.
and for better help? why not post to a BMW forum. (faster)
and no car year, posted or car options listed.
Radio year, model and Car Cell phone options.
no matter.......
the first check on all electronics, is the fuse
most radios have 3 power sources, (to make all features work)
and fuses are on all 3.
have you tried all sources, AM/FM CD, MP3 USB (if opted) .
are all modes dead?
the next check is to try all buttons on the radio. ?
is there a mute button? if car has 4 speaker try the fader lever.
front to rear. left to right , still dead.?
cycle modes. radio, cassette, CD 6 pack , what ever, but do cycle them all as older cars the mode switch can stick.
The RDS is radio station text messages. for song titles.
including time, station identification and programme information.
if this part really works, the RDS part this means the radio is working, but the power amp is dead or muted.
try balance and fader.
many radios (1000s) have fuses in the radio for the speaker amp
that can blow. (shorted speaker wires a prime reason)
or some have in line fuse. and others are in the cars fuse box
which varies by maker or model year.
ok , im looking at the stock radio on level C stock 1991 radio
and even back when (stock to me) the is RADIO muting
so if your car has Cell phone muting bingo that.
and a fuse at rear of radio, (unstated purpose)
guessing,id say there is lamp that glows, CELL mute?
conclusion, no car year stated, or year radio of not origional.
I wish to replace my original bmw e39 radio/casette with a genuine bmw radio/cd player-problem is there is only one multiple round pin socket that fed both units, with the new radio/ cd unit, a seperate...
best advice i can help you with is modernise and fit a aftermarket radio which has usb and sd card support then you will not need the additional CD player in the boot ,old hat now these things when you play a 1 gb sd card and have 30 cds on it .
1helpful
2answers
Have radio code sequence needed for radio reset 1988 bmw 735i
It will depend on the radio MAKE and MODEL
Try asking here
www.ukbookshelf.co.uk
as they offer free advice+code for these older BMW radios
Would like to put the original CD changer/player
To put the original back in just hope the harness behind the radio wasant cut into. If its not it should just plug right in and mount back up in the stock location.
as far as the cd changer. if you would want to add one. you would need to find the changer, harness and headunit from a model with one.
3helpful
BMW Z3 WRONG UNLOCK RADIO CODE HOW TO GET THE RIGHT ONE
If the radio is displaying code wait, or wait, then the ignition and radio must remain on for 1hour. I would contact a dealer within the USA and provide them with your radio serial number. The serial number can be displayed in the radio by pressing and holding down the "M" button while turning on the ignition.
Mar 15, 2009 • 2001 BMW Z3
Adding a remote USB port
I solved my own problem.1 I removed radio1.gif face 2 I removed back cover of radio face to expose USB solder joints.3 I drilled a hole in the back cover of radio face over solder joints 4 I drilled a hole in front cover of radio behind face plate and lined it up with hole in back cover of face plate.5 I cut the male plug off of a USB extension cord and ran it through factory notch on the back of radio,through drilled hole on front panel of radio, thruogh drilled hole on back cover of radio face and soldered wires to back side of USB plug in. Wire colors from top to bottom are Red, White, Green, Black. Solder sheild to any of the three larger solder joints next to these connections. Make sure wires are not touching any other connections. Put radio back together and add screw that locks face to radio. Face can no longer be removed with this wire added. Now I can plug in my 8gb memory stick1.gif,hide it under the dash and have a clean looking installation.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
