Question about Lexmark X5495 Printer
Problem cmmunicating to printer - Lexmark X5495 Printer
Posted by norman durieux on
andrias
    Master:
  • Lexmark Master
  • 443 Answers
Restart your computer after you turn off your printer for ten seconds
Posted on Jul 04, 2014
dagem aberham
    Guru:
  • 123 Answers
Check you data or usb or parallel cable connection and check your pc whether driver is installed or not.
Posted on Jul 23, 2014
Cmmunication between lens and camera is faulty.
Canon can have tight tolerances for their lenses and camera bodies. Some aftermarket lenses don't mate well. If the problem occurs with other lenses as well, try cleaning the contacts on the lens and camera with a clean, soft cloth or rub them VERY LIGHTLY with a new, clean pencil eraser, taking care no particles drop into the camera or lens. If this doesn't correct the issue you probably have a damaged contact or lose contact in the camera or lens.
Trying to print it is telling me the printer is offline. But it is turned on. What do I need to do?
the cmmunication between system and printer is not established.connect the cable to other usb port .check the printer properties by right click on the printer and check use print off line is marked.if so remove the mark by click on it
My scanner has not worked since i purchased this printer. My error is as following: CANNOT CMMUNICATE W/SCANNER. cable may be disconected or scanner is turned off. CODE: 2,155,0. PLEASE HELP!!!!
Follow these steps:
1. Unplug the printer.
2. Uninstall the driver.
3. Re-boot your computer.
4. Then reinstall (from the CD if you still have it)
5. Follow install instructions with printer.
6. Test the printer/scanner/etc.
7. If this doesn't work... go to canon's website and download the most current driver for the printer. then redo these steps using the downloaded driver for step 4.
If this doesn't work, return the printer if you still can.
What wires go into the back of the Dynex 5 Port 10/100 Fast Ethernet Switch?
A switch is a device for networking computers printers or other devices with an ethernet port. Most common scenario would be to hook a cat5 cable from your broadband router's lan port to Port 1 and then connect your other ethernet devices to the remaining ports. In order for the devices to cmmunicate you'll want to make sure that they are on the same ip subnet. Usually, 192.168.1.x.
Your router may be 192.168.1.1, your PC 192.168.1.100 Printer 192.168.1.101. Each device needs a unique IP address.
Hope that helps.
Says computer cnnot cmmunicate with printer have
Remove the printer from your computer ... control panel, printers, delete printer.
Reboot.
Get the latest driver for your printer that is compatable with your operating system and reinstall it following all the manufacturers instructions.
You dont mention the computer, the operating system nor the make/model of printer so it is hard to give much more information than this.
You may want to consider Cclean (search it) as a part of your cocmputer maintenance program. CClean is free to use and free to download. It will remove all kinds of extranious stuff from your computer - it will also assist in cleaning your registry. And lastly, in the tools category, it is a quick way to remove devices and programs from your computer.
Thanks for your interest in FixYa.com
Component Windows Cmmunication Foundation
for this problem you have to reinstall your window.
3answers
Hello. The fan on my Nvidia gforce 7600 graphics card has broken. i was wondering if there is some sort of Nvidia warehouse i can send it to, to get it repaired?
Is it under warranty? If you still have the packaging or warranty info, you can look for a support number there. Nvidia does not usually provide direct support for their products, since they make the chipset but do not make the graphics cards themselves.
If it's not under warranty, it's fairly easy to replace the fan yourself. Replacement fans can be found at http://www.newegg.com/Store/SubCategory.aspx?SubCategory=576&name=VGA-Cooling You only need to unplug the old fan, undo any screws or clips holding it in, put the new fan in its place, and plug it in.
Re Printer error
You have to set this online connection type from the SETUP-ONLINE-ConnectionType and set this to SERIAL if you are using a serial cable. Hope you have selected the port to the correct serial port or you have run the Port detection utility with the printer connected and switched ON while setting up the driver.
1helpful
Pci simple cmmunication cntroller modem driver
Hi rajamke, that statement (PCI simple communication controller modem driver), means your modem is missing it's driver software. If you have a driver CD that came with the PC you should be able to find the driver. There will be more than one. You install the driver that matches your Windows version.
Have more questions, feel free to ask.
Good Luck!
Mike
Lexmark X5495 Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
