My blue mk 2 lay z spa pump when swiched on at the power socket only shows the ambient tempreture and no buttons work on the control panel. I have opened pump and unplugged each module in turn to see if this would identify the problem but still nothing it does show a different error message on the display each time I disconnected the different modules so I think the display works but buttons are doing nothing...can anyone help????
This error code is visible if there is an issue with the water flow sensors in the pump body. Turn the pump off using the On/Off power button on the pump display. ... This should move the sensor into the correct positon Plug the spa back in and reset the pump. This should remove the E01 error code. Unplug the pump. With one hand hold the pump and with the other hit the pump 3 times strong enough to shake the internal components. Plug in the pump,if the control panel still displays alarm E01, please contact your local bestway aftersales service to get instructions.
sounds to me with a power surge you could have a relay on the circuit board not working properly. You will most likely need to change the circuit board to correct the problem.
Checked pump- works, checked heater- works, checked blower- works, flow switch- work, temperature sensors both 56Ohm at 22degrees 6cf is shown when plugged in. If hold buttons and switch the power I can get the blower and water working for split second and 6cf Cuts off relays. I did not found any water detector/preventing the unit working dry ? Does it have one?? Pump, blower, and heater doesn't have any feedback To the pcb it works through relays, I think something else is throwing 6cf. Anything else I have missed?
OHS, OH, or SPA TEMP LMT Message
There is an "Over Heated Spa" (OHS or OH) Water Condition.
One
of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water
Temp and Spa Functions are Disabled. System will Auto Reset when Water
Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High
Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down •
In order for the Spa Water Overheat Error Message to Automatically
Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C). •
Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP
LMT" Spa Water Overheat Error Message has Cleared. If the Error Message
has Not Cleared, the Spa Water is still too Hot to Continue Testing. • Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
888-997-6366 or 866-891-5585 If you call the above number, they should be able to help you find the correct item you need. Have model number ready if possible.
