In the program you got with the printer you have a facility that's lets you clean the heads and Re alien your printer heads this program also helps you to fined out if the ink is low you can find your user manual in main programs under (canon utilities) but if you don't have the manual, www.canon.com.au/en-AU/Personal/Products/.../PIXMA.../MX410 and here you can download drivers updates and the manual.
SOURCE: Canon Pixma MP150
i need to install driver for my canon pixma MP145 printer.
Please help, its very very very urgent
Regards
THIVAGAR
SOURCE: Canon Pixma MP500 error
ok I figured out what to do. Open the over take out all your ink cartriages. Then flip the print head level on the left hand side up and squeeze the top of the print head (where all your ink sits on) and lift it up. You may want to blow off any dust that may be in there and put the peint head back and replace al your ink put the level down and you should be good to go if not you may have to replace the head.
SOURCE: Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
SOURCE: I'm trying to locate the serial number on my
Open the main cover and the head will move into the centre of the carriage.Just to its right face up is a sticker that says serial no: xxxx12345. thats it. I too have a MX410 and its a great little machine.
SOURCE: I have a canon MX410.
I just found a thread in Apple support forum which has fixed this problem for us - we have been battling with it for months. It is probably to do with it thinking it is a USB print queue, instead of wireless.
https://discussions.apple.com/thread/2528609?start=0&tstart=0
Good luck
