Question about HP DeskJet 940c InkJet Printer
Deskjet 940C slow to respond to print commands
It takes 5 minutes at least before the 940 will print what I send to it. Running from a laptop w/Windows XP, 1.7 ghz processor, big drive, and 1 gb memory. This is new. No viruses, registry is clean, disk does not need defrag. DiskClean has cleaned out a lot of rubbish. Still no better. Laserjet 3200 running off same computer is much faster to respond, but slow to find proper printer in dialog box when I click on HP3200.
Hints, please!
Thanks,
Ted
Posted by Chaliceman on
Jose Ramirez
    Sergeant:
  • 263 Answers
First if you are using the printer conector istead of USB cable that is one reason the second one is the setings for your printer you can go to the printer properties click on advance check to start printing imediatelly and thats it
Posted on Jan 03, 2008
Every picture I print has striations through them. My pictures all look like they have been printed on corduroy paper. I am using an HP deskjet 940c. Any ideas?
Hi
The printhead of your color cartridge is clogged
or is near to end
you need to replace the color cartridge or refill it (cheaper method)
check here how
Jan 19, 2011 | HP DeskJet 940c InkJet Printer
How do you get a laptop to print something on your HP Deskjet 940c?
Some 940c printers came with USB and LPT ports, Does your machine have a USB port?
Dec 09, 2010 | HP DeskJet 940c InkJet Printer
My HP deskjet 940c has been out of use for a while and I just started using it again. It now prints like have of a page, stops and continues the rest on another piece of paper. Why and how do I fix it?
put a single paper at a time when u give a printing command. also use good quality papers. Adjust the size of the tray.
i hope this would resolve the problem
Aug 02, 2010 | HP DeskJet 940c InkJet Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
I have put new tri colour cartridge in HP Desktop 940C printer. Black prints but noothing in colour
Hi
Sounds like the cartridge head is blocked.
Try getting something like a jam jar lid and placing some hot water into it and place the cartridge in there for a few minutes and then dab with some kitchen towel...
Works for me, every time
Taz
Nov 09, 2009 | HP DeskJet 940c InkJet Printer
I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Jan 27, 2009 | HP DeskJet 940c InkJet Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
Printer
Have you defragged and scandisked lately?
Are you doing anything while printing.
printing takes a lot of resources. you may also want to buy more ram.
Nov 16, 2007 | HP DeskJet 940c InkJet Printer
Printer slow to respond to print command
I had this issue also. Found it to be a firewall issue.
Norton Internet Security, Vista Home Premium.
I ended up having to create a rule to allow inbound TCP from the laptop on port 135. Fixed it.
ps. Be careful setting up such a rule. Several worms make use of exploits on this port. I was very careful only to allow the laptop to loopback to itself.
Nov 14, 2007 | Canon LASER SHOT LBP-2900 Printer
HP DeskJet 940c InkJet Printer Logo
89 people viewed this question
Ekse
efs_perpends
efs_perpends
