SOURCE: polaroid lcd tv sound only no picture
Hello dougie49
I would first check the back-light and the inverter. usually these are what causes the problems in LCD displays. If the inverter is bad most likely the back-light will have problems. If you need to replace the back-light 9 time out of 10 you will require a new display element.
I hope this helps
Thank you,
Henry A. McKelvey
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
SOURCE: polaroid tda-03211c no picture
I was just looking at my manual for mjne and there is a fuse behind the set in a small plastic box you might check it
SOURCE: no Picture only sound polaroid tv tdx 03211c
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
