Computers & Internet Logo
A
Anonymous Posted on Jul 03, 2014
How do i turn on back light keyboard toshiba sattelite p55
Chris Neary
Level 3:
Master:
  • Toshiba Master 369 Answers
  • Posted on Mar 12, 2015
Chris Neary
Toshiba Master
Level 3:
Master:
Answers
369
Questions
0
Helped
116910
Points
3250
Did you upgrade the laptop to a new operating system?
Try pressing fn+Z see if that turns the lights back on.
  • Chris Neary
    Chris Neary Mar 12, 2015
    You may need to also install the driver for it if you have updated the OShttp://cdgenp01.csd.toshiba.com/content/...
2 Related Answers
Anonymous
  • Posted on Nov 16, 2008
SOURCE: Toshiba sattelite a200 won't turn on
I have seen this on laptops before you might try re seating the memory. I would also remove the battery from the laptop and see if it will start up on ac power only a bad battery will give you a similar symptom.
Anonymous
  • 561 Answers
  • Posted on Feb 10, 2010
SOURCE: toshiba sattelite a300 logo and media player doesnt light
Hi
From your description it sounds like the LED board underneath may be faulty in the sense that some of the LED's may have blown, this can be repaired but i advis that you take to a qualified engineer to assess and then replace
Please leave feedback/vote if my answer was helpful
My Toshiba P55-A512 Keyboard wont light up. Is a setting or a key to hit to make it light back up.
the issue could be with the settings of the keyboard or hardware..
check the kbd settings from the control panel, and bios.. see if that works
For any further assistance, call 1-877-805-1027 TOLL FREE.
Toshiba sattelite pro laptop keyboard not working
if you can get into windows with only mouse please reinstall drivers for keyboard if not start windows in safe mode (after POST screen keep tapping F8 and select SAFE MODE from menu , or simply hit LAST KNOWN GOOD CONFIGURATION - it will repair automatically)
1helpful
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
1helpful
I have Toshiba satellite a200 laptop when i turn on my laptop it has continues beep sound and it doesn't log in
check or change your ram first then also make sure that your keyboard is not having a stuck button.
regards
How to replace keyboard on a toshiba sattelite A-215 laptop
Hi click on the link http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-1.htm , in your case i think you should just start at step:5 ,once you take out the screws be careful removing the plastic connecter they usually open "up"
1helpful
Toshiba sattelite a300 logo and media player doesnt light
Hi
1helpful
Wireless function key combination
Usually on the toshiba it is Fn and F2 or F4 the f key will have a coloured picture of an antenna with waves coming off of it.
Also most toshiba laptops have a physical switch on the edge of the case below the keyboard. Make sure that switch is on first then try the Fn and function key combo as they work together like a two way light switch. Both must be on for the card to be active.
Chris
Armor-IT
2answers
This is a common problem for toshiba laptops, unfortunatly. Usually when this happens either your laptop charger is fried, or you will need to replace the actual laptop plug inside the laptop.
2answers
Try removing the battery. It might be faulty and shorting the adapter.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
