SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever
heard of this? Part runs about 300 bucks. TV is out of warrenty as it
is 2 years old. Do you think it is worth it to fight sony and get them
to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
SOURCE: Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
SOURCE: Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
