Question about Canon MP-25DV Calculator
How to set date and time on canon mp25dv calculator
Carlton Thomas
How to Set the Time & Date for a MP25DV Canon Calendar & Clock Printing Calculator
The steps listed in the Calculator Instruction Manual for the Canon MP25DV Calculator did not work.
The correct steps for setting the time and date on this calculator are listed below:
1. Press the time/calendar button one to select the date mode. The display should show the month-day-year.
2. Hold down the = button until the month start flashing.
3. Use the number keys to enter the current date, month and year. Example 07-22-2021
4. Press the = key to set the current date.
5. Press the CE/C key to return back to the calculator mode.
6. Press the time/calendar button twice to select the time mode. The display show the
hour-minute-seconds & time of day. Example 02-01-14 A
7. Hold down the = button until the hour start flashing.
8. Use the number keys to enter the current time.
9. Press the X button for (A) a.m. or (P) for p.m.
10. Press the = key to set the current time.
11. Press the CE/C key to return back to the calculator mode.
12. To check the current date and time on your calculator, press the calendar/time button once
for date and twice for time.
Posted on Jul 22, 2021
2 Related Answers
old marine
old marine
  • 2366 Answers
SOURCE: set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Posted on Feb 26, 2009
Anonymous
SOURCE: How do you set the date and time?
1) press calendar clock button
2) hold the time and date button for 3 seconds, this button is marked with "Time and Date" one the keypad and not on the button itself
3) The date or time should start blinking
4) make inputs of current date and time
5) press Time and Date button again to save changes
6) All set!
Anytime you want to display the date or time hit the clock and calendar button. The calc will hold the display until u switch to the calculation mode i.e. by pressing the CE/C button.
DUHHHHHHHH!!! All these instructions are in the piddly sheet Canon calls the manual.
Posted on Feb 06, 2010
1helpful
When I enter a number using the + button, it often adds it multiple times
You may be pushing it down to hard or holding it down for too long. Try pushing and releasing it very quickly.
Good luck,
Paul
How do I put a new ribbon in a Canon MP25DV
Top right column on page 3: http://www.manualslib.com/manual/355936/Canon-Mp25dv.html
11helpful
Need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
8helpful
6) All set!
35helpful
Set the time and date on a canon mp25dv/instructions
To set date:
To set time:
7helpful
Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
2helpful
2answers
Setting the tax rate on Canon MP25DV
the rate button is the 2nd slide switch from the right.. just above the GT key.
10helpful
2answers
How do you set the clock/calendar on the Canon MP25DV?
The trick is to hold down the time set button (=) until the time flashes and once the new info is entered, press time set and it will stay.  same with the date.  You kinda need to play around with it.  Thats how i learned.
278helpful
7answers
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Canon MP-25DV Calculator Logo
old marine
old marine
Ekse
