Question about Sharp Wizard Oz-640 Electronic Personal Organizer 512kb
I haven't used it for a long time; put new batteries in, but won't turn on
Sharp Wizard 512 KB not used for a few years. Replaced batteries, but can't turn it on. Is there anything else I can do to turn it on?
1 Related Answer
cq92
Larry S
  • 184 Answers
SOURCE: i have an OZ-730 sharp wizard and it will not turn
Be sure the batteries are in correctly and are good, be sure the battery switch is back to the "normal position" - also it may have to be reset to work again - here is the instruction manual for doing that , page 7 chapter 1:
http://www.promsoft.com/dev/oz700sdk/oz7xx_manual.pdf
Posted on Oct 29, 2009
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
May 29, 2017 | 1998 Honda Accord
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
I haven't started my 1988 Chevy 305 truck in a few years. I put a squirt of lubricate in each cylinder, made sure there was oil and coolant, and a new battery. When I tried to turn the key it wou
I would check to see if you are getting 12 volts at the starter. You should have one wire coming from the ignition that gets system voltage when you turn the key to the start position. You'll also have one from the battery that will be hot all the time.
Dec 21, 2017 | 1988 Chevrolet K2500
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
The lap top don't recognize my battery
If you haven't replaced the battery in recent years, it is entirely possible that the battery is fully dead and won't be detected by the operating system. You can try taking the battery out and putting it back in. Updating the BIOS on the laptop with this could also be worth a shot as it can correct battery detection issues.
Aug 23, 2011 | Compaq Presario X1000 Notebook
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
I have an OZ-730 sharp wizard and it will not turn on, batteries are new and i tried the reset button. last time i used it the screen went black and then it turned off? help
Sep 17, 2009 | Sharp Wizard OZ-730
Sharp Wizard Oz-640 Electronic Personal Organizer 512kb Logo
41 people viewed this question
Top Sharp Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Robert Rankin
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
