It's a timing belt, so it isn't supposed to stretch. There is no tension adjustment that I can see. Are the 4 motor screws in place and tight? Is either the motor or the kneading paddle drive shaft turning in its drive wheel? Is the frame bent and causing the belt to walk off one of the pullies? Another problem can be that the bearing in the pan won't turn, then you'll get a loud bump as the drive mechanism tries to turn the paddle in the pan. If this happens, try to free up the paddle by hand so it turns. Then when you bake, always put the oil in the recipe in first and rotate the paddle a few turns to work the oil into the pan bearing. If the oil gets in first, it will keep the water out and the pan will work fine. I've been getting away with this approach for hundreds of loaves.
Hi Anonymous, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
