This time of the year rarely a week goes by that we don't get a call from someone stating that their remote car starter stopped working. Nearly every call is the ...
Sep 29, 2013 - You press the button on a cold Winter day to find that your remote starter stopped working! Take a deep breath. It is probably something very ...
? 1:02
https://www.youtube.com/watch?v=EuHu2VFx0ks
Nov 4, 2012 - Uploaded by daniluchison
Remote controls sends signal to Remote Starter but after a few 'clicks' it won't start the ... 04-08 Pontiac ...
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground. Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Aftermarket remote start systems are notorious for starting concerns due to the fact THEY ARE BYPASSING YOUR THEFT DETERENT FROM THE FACTORY.Definately in the remote start system.Are you using the factory remotes to open the doors?
Does the remote work? If the remote is working, then check the hood pin. Hold down the hood pin and remote start the vehicle with the remote. If the remote start fails to work,check the neutral safety shutdown switch. It's a toggle switch under the dash.
If the keyless remote works to unlock and lock the doors, then it should start the engine. In order to use this feature, you have to lock the doors (make sure that all door lock by pushing the lock button twice) with the remote by pushing the lock button, then you hold down the start button on the remote for 2 to 3 seconds and it should start. You can start and stop the engine with the remote 2 or 3 times with the remote, after that it will no longer let you use the remote start until you physically get in the car and start the engine to reset the system. Check your driver information center options using the steering wheel controls. There is an option to enable and disable the remote start option.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
