Question about Music
My boss BR 1180 digital recorder has suddenly stopped playing back in stereo. Sound from left side only. I checked older recordings on the machine and it does the same thing. VU meters show sound on both left and right. Checked with 3 different headphones, and checked pans, no sound on right.
1 Related Answer
CRTN
Michael Fisher
  • 716 Answers
SOURCE: I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Posted on Jan 05, 2009
I am getting "CD Write Error" on my BR-1180 when attempting to burn a track. It is sporadic; sometimes I get a burn, but lately it has increased and I have now gone through 15 cd's and getting this...
MICHAEL SCOTT: YOU PASSED ALONG SOME GREAT INFORMATION BUT IT ONLY GETS ME HALFWAY THERE...
I HAVE ALL THE NECESSARY CABLES HOOKED UP. DO YOU HAVE TO RECORD MY SONG FROM THE 1180 TO AUDACITY OR WHAT?...THIS IS ALL NEW TO ME AND IT MAY WORK BUT TELL ME HOW TO RECORD FROM THE 1180 TO AUDACITY.
THANKS...GEORGE SLADEK
Aug 18, 2010 | Boss Micro BR Digital Recorder
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
May 23, 2010 | Boss Micro BR Digital Recorder
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
Apr 15, 2010 | Boss Micro BR Digital Recorder
I was listening to a play back of a song i was recording when everything stop and window indecated that DRIVE BUSY Don't know what to do?
if it came back after a while then thats the way it is with digital recording sometimes. if it didnt come back that indicates something more serious.
Dec 20, 2009 | Boss Micro BR Digital Recorder
I bought a used BR 532 Boss recorder - can't get a
I get an unformatted come on the screen on my Boss BR 532 when I swith on, and also when pressing record, although I can get drum machine to work and guitar go through it ok but no recording Hmmmm Erggg
Nov 16, 2009 | Boss Micro BR Digital Recorder
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Dec 24, 2008 | Boss Micro BR Digital Recorder
MY Boss br 1180 ,disk error
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
Dec 06, 2008 | Boss Micro BR Digital Recorder
Music Logo
24 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
