Krups Dolce Gusto KP 2100 Espresso Machine Logo
A
Anonymous Posted on Jul 02, 2014
What is likely cause of dolce gusta machine not switching on
NESCAFE Dolce Gusto Mini-Me brew lever.
You can try and fix it, or contact Nescafe and ask for a warranty replacement.
https://www.google.com/search?q=dolce+gusto+mini+me+service
My nescafe dolce gusto mini me is leaking milk from the bottom so some milk is going into the cup and the rest on the worktop. Any ideas?
If your Nescafe Dolce Gusto Mini Me is leaking milk from the bottom, there may be a few possible causes:
  1. Check the milk capsule: Make sure that the milk capsule is inserted properly and is not damaged. If the capsule is damaged, it may cause leakage.
  2. Check the milk frother: If the milk frother is clogged or not working properly, it may cause the milk to leak from the bottom. Try cleaning the frother and see if the problem persists.
  3. Check the machine: Check the machine for any cracks or damages that may cause the milk to leak. Also, make sure that the water tank and drip tray are properly in place.
  4. Contact customer support: If none of the above solutions work, contact the Nescafe Dolce Gusto customer support for assistance.
In any case, make sure to clean up any spilled milk thoroughly to avoid any safety hazards.
1helpful
Dolce gusto light turns yellow more orange. What is going on?
To solve you oregne light problem you must do this press power bottom for few seconds to make it flashing Orange this means that the machine is now in descaleing mode then do the descaleing product be sure you use dolce gusto descaleing only after you done reset power bottom this should solve the problem.that was a working for descaleing
1helpful
2answers
Dolce gusto problem
In my case problem was dry/old electrolitic capacitor.
Label on PCB - C2
Value 470u/10V 105 degC
18helpful
3answers
How do you descale the machine
my machine has stopped working it sounds like the motor is still running, not sure where to buy the descaler can I just use vinegar?
5helpful
2answers
I have a Nescafe Dolce Gusto coffee maker and when you press red switch it will not go to green
Hi Ron, my name is Katelyn, and I help with the marketing for Dolce Gusto. There is a live chat2_bing.gif with a specialist on our Web site (http://www.dolce-gusto.us/Public/Contact-Us.aspx) or feel free to call the consumer services at 800-745-3391.
50helpful
4answers
How do I descale a Krups Dolce Gusto machine?
_451.jpg_450.jpgSorry about picture quality, fixya only let you upload small file sizes
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
