Question about Parallax Power Supply Parallax 7300 Series Electronic Converter/Charger, 55A
Why does the cooling fan run all the time ?
When its plugged in to AC it runs all the time
Posted by Orlando Tatone on
  • mwredd Oct 14, 2014
    The cooling fan should not run all the time. The cooling fans in your converter are designed to come on when needed to cool the DC converter section or converter unit only. The fan circuit is controlled by a thermister and is triggered primarily by the amount of DC current the converter is supplying to the DC system while the converter is powered on.
Troy Crowder
    New Friend:
  • 33 Answers
I suggest you call Parallax Power Supply
100 W 11
th
St. Suite 100
Anderson, IN 46016
Ph: (800) 443-4859 Fax: 765-608-5235
Posted on Jul 02, 2014
Why are my cooling fans for radiator running constantly?
The cooling fans are supposed to run any time the a/c is on in order to keep air flowing across the condenser. Your a/c will not work properly at idle if they quit.
Jul 27, 2015 | 2010 Ford Escape
My 1994 Toyota Previa LE overheats when I put on AC. It overheats while on idle.
cooling fan not running.check for faulty cooling fan relay or fuse.cooling fan fan should be running when you turn on AC.hotwire cooling fan make sure cooling fan motor okay.
Jul 10, 2013 | Cars & Trucks
P0481 on grand prix 2002. cooling fans work with a/c on and relays seem ok. vehicle temp gauge opertaes ok and does not seem to get hot.
sounds normal, the fans were made to run continuous w/ ac running, but on sensor when ac is off. if car isn't overheating, the fans are probably running from time to time ,but your just not catching them running
Sep 04, 2009 | 2002 Pontiac Grand Prix
When I turn on my a/c the car starts to everheat
When ever the car overheats,it is always the best thing on your car,to check the cooling fans.When the ac is on,look to see if the cooling fans are running,and running fast,and smoothly.In your case,I am going to go out on a limb,and say they are not.First check for blown cooling fan fuse.Then,if the fuses are alright,check the cooling fan relays,most likely more than one.One prong,or spade coming out of the relay,is ground(where it plugs up).To make the relay energize,ground this terminal with a test light .Just like you are using the test light to check for 12 volts.When you touch the ground spade on the relay it will energize the relay to turn the fans on.Just pull the relay out of it`s spot,just enough to touch the spade.Do this with the ac on,and engine running.The clutch relay on most cars will energize the relay,but the ac compressor is working on your car,so it is either the fan relay,or the high side switch on the ac system that is bad.Try and see if the cooling fans,both of them,or one of them,will come on by them selves as the car warms up,with the ac off.The fan or fans should come on,and go off by themselves.Don`t let the engine overheat,keep a good eye out not to let that happen.If the fans never come on,then,the fan,or fans could be bad.You can test them by running wire from battery to the fan,and grounding to frame.Now the fuse,or relay being bad will also cause this.If a fuse is blown,then ,one or more of the fans are bad,and will have to be replaced.The fans cool the radiator for the engine and transmission cooling,and the condenser for the ac system.If the condenser is not cooled down,the ac freon will be to warm to cool the vehicle.If I can help,let me know.>>[email protected]
Aug 26, 2009 | 2000 Honda Civic
Mercedes benz airconditioning
You might check the cooling fans on the condenser to see if they are running when the ac is on.If they are not check for blown fuse,or bad cooling fan relay.Do you notice if the ac cools better when running constantly,and the ac is not so cool when in traffic,stopping and going,and running slow?If so the cooling fan,or fans are not working.If the fan fuse and the relays check out fine,then replace the fan,or fans.If I can help any more please [email protected]
Aug 19, 2009 | 2004 Mercedes-Benz C-Class
Kia over heats when air is on only
your AC cooling fan is not working properly, most vehicle has two fans, one for the radiator and another for AC, both work in sync with one another; if one cooling fan only working it does not produce enough cooling for both radiator and condenser at the same time; by running ac you producing more heat and its cant cool the engine fast enough with one fan so your engine is overheating when running AC. The temperature sensor could be faulty and need to be replace or your fan motor can also be faulty. Check the fuse first and the relay make sure they are not burn out. sensor cost about 30 bucks get it new, relay 35-40 new used 5 bucks at junk yard, fan get it from a junk yard for 25-30 bucks, new will run over 100 bucks. don't run the air and overheat your motor, it can damage your engine or may blow your radiator. if you do run ac watch the temp very closely, don't let temperature get into the red.
Jul 10, 2009 | 2002 Kia Sportage
Ac fan does run
you mean it is not running, ok it will run the same time with the compressor, monitor if the compressor clutch engage while fan not ,check supply going to the fan if present. The fan is damaged and need to be repair.
Jun 12, 2009 | 1993 Mazda MX-3
Cooling fans will only turn on if engine is off only
Electric cooling fans do not run all the time. They will only come on if the engine exceeds normal operating temp. Also will run when AC is on. Easiest way to make sure they are operating properly is to first verify they run when the AC is on. Next turn the AC off and run the engine at 2500 rpms sitting still and monitor the temp gauge (don't let it get into the red). The fans should come on after 10-20 minutes (depending on outside temp.). As the engine cools down they will turn off.
Jan 04, 2009 | 1995 Honda Accord
2000 sebring. Overheats with air conditioning on.
I just had my coolant flushed and my radiator cooling fan replaced. The car was slightly overheating and would "gargle" in the coolant bowl after I turned the engine off. It turned out to be the radiator was clogged up on one side.
I went full tilt and replaced the radiator, water pump, thermostat, radiator cap and timing belt. I have 85,000 miles on the car and it was about time to do these things anyway. It is running like a new car now.
Jun 15, 2008 | 2000 Chrysler Sebring
Parallax Power Supply Parallax 7300 Series Electronic Converter/Charger, 55A Logo
272 people viewed this question
Top Parallax Power Supply Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Parallax Power Supply Electronics - Other Expert? Answer questions, earn points and help others
