Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
My wave touch display is giving me a t3 error code when I turn the ice maker on
Good Morning Friend,
I understand you are receiving a T3 error code when you turn the ice maker on your Electrolux refrigerator. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure your ice maker is on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Posted on Jul 08, 2014
SOURCE: I have an electrolux wave touch french door
pull the ice tray out, on the bottom of the left side there's a metal rod that needs to be repositioned into the tooth gear.
Posted on Oct 22, 2010
SOURCE: French Door with bottom freezer Electrolux ice
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Posted on Dec 11, 2010
SOURCE: ice t3 error
check water supply line for blockage. check lever is operating correctly. empty tray and see if it makes ice.
Posted on Dec 10, 2013
Hello p_shields123 - Could the actual error code display be "ICE T3"? If so, it typically indicates that the TH3 thermistor in the Fresh Food Ice Maker compartment is shorted or open. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to move forward accurately and to properly assist with the repairs.
Hello Alan Gibson - Are you certain the error code is P0? This manufacturer does not have an error code P0 for any dishwasher or other units. Could you please try reprogramming the unit by flipping the household circuit breaker off or unplugging it? Wait approximately ten minutes and restart dishwasher. If the unit is experiencing a generic communication error, it should be follow by another fault code. What is the error code? If it continues to display P0 then consult a professional to move forward accurately.
Hi - Error code E01, typically indicates that a water leak has been detected under the tub. Unit may possibly need a hydraulic kit; however I would suggest contacting a professional to move forward accurately.
