Question about Canon PIXMA MP170 All-In-One InkJet Printer
How to fix a error code u051 on canon mx700 printer
5 Related Answers
Anonymous
SOURCE: u051 error showing / Will not accept ink
when the message appears, hold the reset button for about 5 seconds, this disables ink monitor on most canon models
Posted on May 29, 2008
Anonymous
  • 71 Answers
SOURCE: Error Code 5100
Carriage error. Paper or the print mechanism is blocked.
It could mean the rollers don't grip the paper, there is torn paper keeping the rollers from turning, the paper can't stick to the rollers etc.,
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Posted on Sep 01, 2008
komguy
Craig Gillette
  • 2306 Answers
SOURCE: error code 5100 on canon pixma mx700
5100 says the carriage is not moving all the way across the paper path. There could be grease or ink on the encoder strip, the clear strip behind the carriage. Or a small paper scrap inside stopping the carriage.
Posted on Aug 10, 2009
Anonymous
  • 787 Answers
SOURCE: canon mx318 u051
Try to press and hold the resume button for 5 seconds.If this not help you need to replace the ink cartridges.
Posted on Oct 26, 2009
Anonymous
  • 8 Answers
SOURCE: Error Code 6A80 on the Canon MX700
Supply Guy,
Here is the solution.
I am going to describe 4 buttons on your printer. Then, I will tell you what to do with these buttons to resolve this error.
1. Look for the Black & White selection button (large white button w/ black diamond on it).
2. Look for small pink button (bottom left corner of your printer control panel).
3. Look for the OK button (big button in middle).
4. Look for the On/Off button (top left).
OK - here we go. With the printer turned off, do this:
1. Using four fingers, one on each of the four buttons, press them all and hold them down for 10 seconds.
2. Release the On/Off button - but keep holding the other 3.
3. After a few more seconds the printer will turn on. When it does this, you can release the other three buttons.
So, to summarize, you press all 4 buttons for 10 seconds, release the power button and wait for the printer to turn on. After it is on, let go the other 3.
Your error message should go away. If you don't hold the buttons all down simultaneously, the printer could go into Fax mode; just turn it off and try again.
Posted on Dec 29, 2009
ERROR U051 MX320
Error code U051 indicates that print head temperature error. This usually happen when ink is almost empty. The solution is to replace the cartridge with new one.
Source: Printer Clinic
Aug 29, 2012 | Canon PIXMA MX310 All-In-One Printer
Printer eror code U051
Instructions
    • 1
      Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
    • 2
      Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
    • 3
      Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
    • 4
      Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
    • 5
      Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
    • 6
      Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
    • 7
      Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Mar 07, 2012 | Canon MX700 Office All-In-One InkJet...
Canon Mx 300 Printer wont work
Error Code [1401] or CHECK INK U051 = cartridge may not install properly or using non-genuine cartridges, refilled cartridges or faulty cartridges.
May 27, 2010 | Canon MX300 Office All-In-One Printer
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer error on a canon mp 470
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to [email protected]
Jul 26, 2008 | Canon PIXMA MP470 All-in-One Printer
U051 printer error message
tengo unb problema con la impresora canon pm170, me sale unmensaje de error COMPRUEBE LA IMPRESORA,
May 24, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP170 All-In-One InkJet Printer Logo
721 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
