John Deere 22HP VTwin 48" Riding Mower Logo
A
Anonymous Posted on Jul 02, 2014
Why is my john deer riding mover backfiring and how do I stop it.
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on May 09, 2009
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
nova2nv
Bill Linda Rivard
  • 197 Answers
  • Posted on Nov 14, 2009
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
Anonymous
  • 742 Answers
  • Posted on Apr 19, 2010
SOURCE: manual for john deere sx95
ask manualfox.com - they have it.
Anonymous
  • Posted on Aug 12, 2010
SOURCE: LA150 john deere riding mower transmission slips
this transmission is a sealed unit, no way to add fluid or change filter.
brado83
Brad Wilkinson
  • 106 Answers
  • Posted on Aug 01, 2011
SOURCE: Need to replace the belt
HI,
2007 riding mower John Deere backfires while trying to start will not start
Inspect/replace the air filter to ensure proper air flow.
Inspect/replace the sparkplug(s) to ensure proper firing.
Check the position of the "choke" (if equipped; & by the way, most riding lawn mowers do not use a primer bulb button to prime the engine before starting).
John deere riding lawn mover doesn start, said, code 7.6
Gas is bad these days. If it's turning over but not starting, Pull the plugs and replace, they are cheap. Drain the gas out and add high test with no ethanol. Add a couple drops of a fuel jet cleaner. Turn it over a couple times. Don't panic if it does not start leave it sit overnight, then start. Check the gas filter and air filter as well. Nothing here expensive. Unlikely anything else wrong unless someone was paying with the carburetor or choke.
John deere troubleshooting
Please refer to this site for details on trouble shooting manuals. I am hoping you are after John Deere tractor lawn movers etc.
Troubleshooting
My John deer start and then die replaced the fuel filter
There are not of reasons for lawn mover starting and then dying.
Please see this John Deer site for possible causes and fixes.
Troubleshooting
Sep 03, 2014 • Garden
John Deere L130
I have not worked on these lawn mowers but there is plenty of posts on different lawn mower sites on how to rebuild the John Deere L1xx series transmissions. I would suggest have a read of this site. It also mentions the parts required and the cost. I understand these lawn movers use the K46 transmission system.
TuffTorq K46 Repair Guide with Pictures
Aug 15, 2014 • Garden
1helpful
No power when engage mower deck John Deere F910
Mine acted the same way. Found out I had lost a cylinder. I would check your compression before doing anything else.
2answers
Need carburator ajustment / john deere lx176/14hp kawasaki
i have 14hp kawasaki that backfire throw the carb and exhaust what could it be
Jun 05, 2012 • Garden
3answers
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
