SOURCE: installing correction tape on brother sx-4000 typewriter
If this is hard to see you can get the manual here
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF
SOURCE: I'm having a problem installing a new "correction tape"
Lost manual need to know how to reset margin
SOURCE: after typings a line and hit return the carrige
The plastic gear on the feed motor is broken. The motora are available with a brass gear, about 35.00.
DickyO
SOURCE: how to install correction tape in brother sx-4000
Go to brotherinternational.com, Click on support nyou will find a manual there.
DickyO
SOURCE: how to install correction tape on a brother sx 4000
Go to Brotherinternational.com, click on support you will a manual there.
DickyO
There are two things that people mess up when changing printwheels and ribbons. Is that the ribbon is not in the guides properly. The other is that the latch the holds the type wheel is not locked in the forward position.
