Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS3R5EMB, does not release the ice cubes from the dispenser. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try to dispense ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid. The solenoid is bad. When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out. First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down. You can take out the ice bucket and press for cubed ice. You should hear a loud clunk noise. If not then you know the solenoid is not working.
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
SOURCE: Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
SOURCE: ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
